Seasonic X-Series 1250w '80 Plus Gold' Modular Power Supply @ £199.99 inc VAT
Common to all X-Series power supplies, the new X-1050 and X-1250 feature the unique integrated DC connector panel with onboard VRM (Voltage Regulator Module) that enables not only near perfect D-to-D conversion with reduction of current loss / impedance and increase of efficiency but also a fully modular DC cabling that enables maximum flexibility of integration and forward compatibility.
An industry first, advanced 3 phased (Fanless, Silent and Cooling Mode) thermal control balances between silence and cooling. In addition, for X-1050 & 1250 a selector switch is provided to allow you to select between the Seasonic S2FC control, without fanless mode or the S3FC fan control, with fanless mode.
The world-renowned Sanyo Denki Ball bearing fans are made of the highest quality components to ensure maximum quality and performance. The use of spoon shaped high-density plastic fan blades with smoothed leading edges, strict tolerance ball bearings and precision copper axel are just some features to ensure ultra-low noise performance and quality. In addition, the fan uses 3 balancing points, instead of the industry standard of 2 points, to ensure perfect balance and rotation. The Sanyo Denki fan is a perfect match to the class leading Sea Sonic Hybrid Silent Fan control for the absolute top performance of the industry.
- 80PLUS® Gold Certified Super High Efficiency
- Full Modular Cabling Design
- Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
- DC to DC Converter Design
- Seasonic Hybrid Silent Fan Control
- Sanyo Denki San Ace Silent Fan
- Conductive Polymer Aluminum Solid Capacitors
- Highly Reliable Japanese Brand Capacitors
- Tight Voltage Regulation [±3%]
- Active Power Factor Correction [99% PF Typical]
- High +12V Output
- High Current Gold Plated Terminals
- Dual Sided PCB Layout
- Ultra Ventilation [Honeycomb Structure]
- Multi-GPU Technologies Supported
- All-in-One DC Cabling Design
- Easy Swap Connector
- Universal AC Input [Full Range]
- 5 Years Warranty
Only £199.99 inc VAT.
ORDER NOW
_____
Avexir Core Red Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CIR) @ £49.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Mpower Red Series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Red high performance heatspreaders
- Red LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 9-9-9-24
- Dual Channel Kit: (2x4GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £49.99 inc VAT.
ORDER NOW
- High +12V Output
- 5 Years Warranty
ORDER NOW
_____
Features:
- Black PCB
- Lifetime Warranty
ORDER NOW
