**Today Only 05/03/2012** Sharkoon T28 Midi Tower Case & Western Digital Caviar Green 1TB (single pl
22 Aug 2010
Today Only special offers.
With a cool blue interior the Sharkoon T28 Midi Tower Casechassis dignifies superiority and a level of wealth.
We also have a Western Digital Caviar Green 1TB featuring a Single Platter design for better performance.
Sharkoon T28 Midi Tower Case - Black/Blue @ £51.98 inc VAT
The T28 series includes three ATX cases in which the mainboard mount, slot apertures, quick-fastener levers and the hard drive mounting frame are colored against an otherwise black case finish. Available color variations are red, green and blue.
Three pre-installed 120 mm fans illuminate to properly match the color of the interior – two in the front, one in the back of the case – also in red, green or blue. The installed acrylic side window allows view of the components inside the case.
The T28 case offers installation options for a maximum of two optical drives and up to eight 3.5" hard drives, which can be installed either using the provided mounting rails or attached directly using the two mounting frames. These mounting frames are also suitable for installing 2.5" hard drives, such as SSDs.
The central hard drive cage allows graphic cards to be installed up to a maximum length of 40 cm, and also be quickly and easily removed from the case.
The ports on the T28 are easily accessible on the front panel of the case. A USB3.0, three USB2.0 and audio ports are available.
Found in the back of the case are the usual mounting slots for seven extension cards, a lying down power supply, two hose feedthroughs for water cooling and the I/O cover of the mainboard.
Multiple possibilities to conceal installed cables, an installation opening for CPU coolers in the mainboard backplate, pre-installed quick-fasteners for the optical drives, a detailed instruction manual available for download and a comprehensive accessory set round out the overview of a high-quality PC case for all areas of application.
- ATX case
- 2x 5.25" drive bays (external)
- 6x 3.5" HDD bays (internal)
- 2x 2.5"/3.5 "HDD bays (internal)
- Front I/O with 1x USB3.0, 3x USB2.0, 2x audio
- Acrylic side panel
- 7 slots for add-on cards
- Mesh front panel
- Quick fasteners for optical drives, mainboard mounting panel with installation opening for coolers
- 2 openings for water cooling
- Cable management system
- Dimensions: 475x200x440 mm (LxWxH)
- Weight: 6.6 kg
- Case front: 2x 120 mm LED fans (pre-installed)
- Rear panel: 1x 120 mm LED fan (pre-installed)
Only £51.98 inc VAT.
ORDER NOW
Western Digital Caviar Green 1TB SATA 6Gb/s 64MB Cache - OEM (WD10EZRX) **SINGLE PLATTER** @ £75.98 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
This new model uses a single platter design which has the benefits of improved performance.
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA-6
- Spin Speed: IntelliPower
- Warranty: 2 Years
Only £75.98 inc VAT.
ORDER NOW
