**Today Only 05/06/2013** Asus Xonar DG 5.1 PCI Sound Card & Speedlink Spes Clip-On Metal Microphone
22 Aug 2010
Today Only Deals!
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM @ £17.99 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
- OEM Bare card.
Driver location: http://uk.asus.com/Multimedia/Audio_Cards/Xonar_DG/#download
Only £17.99 inc VAT.
ORDER NOW
Speedlink Spes Clip-On Metal Microphone (SL-8691-SBK) @ £4.99 inc VAT
The microphone is attractively designed and is extremely practical. The noise-suppression system filters out bothersome background noises and makes internet chat easy and uncomplicated. Furthermore, the clothing clip allows you to clip the mic anywhere you like.
- Lots of freedom of movement thanks to the 2.4m cable
- You'll hardly notice you're wearing the mic thanks to it's low weight
- Easy to attach to clothing thanks to the clip
- Highly sensitive microphone featuring noise suppression
- Robust design made from black metal
Only £4.99 inc VAT.
ORDER NOW
Would the sound card work with this?
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard
Gigabyte Radeon HD 7950 PCI-3.0 3072MB GDDR5 384 BIT graphics card
Windows 8?
Windows 8?
Yes, can't see why not. Motherboard has a PCI slot and drivers are available to download for the Xonar DG from Asus' website for Windows 8. Just be sure to get the correct one for your OS; 32bit Vs 64bit.
