**Today Only 05/10/2012** BitFenix Prodigy 'Yin' Mini-ITX Cube Case &
22 Aug 2010
Today we feature our own mixed up creation of the yin Prodigy case. Mixing up the styles we have recreated the case with a fresh look!
BitFenix Prodigy 'Yin' Mini-ITX Cube Case - White/Black @ £59.99 inc VAT
We have made some amazing improvements to the Prodigy cases. Opposites attract. Yin-Yang / Vice-Versa / Black-White / Light-Dark / Hot-Cold etc. These new options offer great new stylish designs.
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex™ Composite for easy portability and maximum shock absorption. The spacious internals give you the flexibility to install up to five 3.5" hard disks or no less than nine SSDs. The modular FlexCage™ can also be removed entirely to fit long graphics cards and water cooling radiators up to 240mm in length, and a choice of Midnight Black or Arctic White with available interchangeable face plates mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch™ Surface Treatment, Prodigy is the compact case with no compromises.
- Beautifully Compact – Mini ITX dimensions with clean modern styling
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- BitFenix FyberFlex™ Composite Handles – For portability and shock absorption
- Maximum Storage Potential – Install up to five 3.5" or nine 2.5" SSDs
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- Choose Your Own Style – Two color options and interchangeable face plates available
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Trouble-free Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
- Dimensions (WxHxD): 250 x 404 x 359mm
- Motherboard Sizes: Mini-ITX
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 5 (3 + 2 modular)
- 2.5” Drive Bays: x 9 (5 + 2 + 1 +1 )
- Cooling Front: 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1(optional)
- Cooling Top: 120mm x 2 (optional)
- PCI Slots: x 2
- I/O: USB 3.0 x 2, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Only £59.99 inc VAT.
ORDER NOW
Noctua NF-P12-PWM 120mm Silent Case Fan - PWM Pin @ £16.99 inc VAT
The NF-P12 has been specifically developed for applications such as CPU coolers that demand superior pressure and airflow performance. Thanks to psychoacoustic optimisations like the Vortex-Control Notches, the new SCD Drive System and Noctua’s premium-grade SSO-Bearing, the NF-P12 achieves exceptional quietness and long-term stability.
- Fan Speed: 1300RPM / 1100RPM / 900RPM
- Airflow: 54.3CFM / 46.2CFM / 37.3CFM
- Fan Noise: 19.8 dB / 16.9 dB / 12.6 dB
- 4 Vibration Compensators, 4 Fan Screws, 3 to 4-pin adaptor
Only £16.99 inc VAT.
ORDER NOW
You have to get rid of your whale of a mobo too then?
Yep,
Gonna see what I can get for my setup, minus the 560 ti.
That's what I thought when the Prodigy case was first listed here. :D
lol.
Bloody missed out on a used one lastweek with used asrock MB and bitfenix fan controller for very cheap :(
If I can change over from my setup to one of these with 2600k and not have to spend more then around £250ish I will.
