- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello Today only we have 100 units of Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with BattleField 3 & Batman: Arkham City PC game**
We also have 20 units of Corsair Gaming Audio Series HS1A Analogue Headset
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with BattleField 3 & Batman: Arkham City PC game** @ £194.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
- Supplied FREE with Batman: Arkham City FULL PC game (subject to availability. Game is launched on 21/10/2011 downloads previous to this date will be declined) (Only supplied with orders purchased after 07/09/2011)
- Supplied with BattleField 3 Full PC Game download voucher!
Was £199.99 Inc. VAT
Only £194.99 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1A Analogue Headset @ £29.99 inc VAT
The Gaming Audio Series HS1 Gaming Headset is designed for gamers who are serious about audio. Massive 50mm driversdeliver serious punch, without sacrificing the sparkling sound quality you need for music and movies. Extra-large, extra-deep memory foam earpads provide a reliable, custom fit that’s so comfortable, you might forget you’re wearing them.
- Massive 50mm drivers for high-quality audio reproduction
- Detailed audio reproduction with clean, accurate bass and sparkling clarity in mids and highs
- Circumaural, closed-back earcups for superior noise isolation
- Memory foam earpads provide a custom fit that won’t weigh you down
- Includes two sets of earpads to customize your comfort – your choice of microfiber or synthetic leather
- Connectivity: 3.5mm jacks for ear piece and mic
- 2 Years Warranty
Was £33.98 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Features:-
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
ORDER NOW
- 2 Years Warranty
Was £33.98 Inc. VAT
ORDER NOW
