**Today Only 06/02/2012** NZXT H2 Classic Silent Midi Tower Case & Steelseries Sensei Pro Laser Gami
22 Aug 2010
Today only deals with limited deal stock.
Steelseries Sensei Pro Laser Gaming Mouse (62150) @ £62.99 inc VAT
Based off the critically acclaimed Xai gaming mouse, the SteelSeries Sensei is a top of the line laser gaming mouse dedicated to suiting tournament level players. It features a highly sophisticated firmware that allows for multiple adjustments of the sensor functionality, as well as complex macros to customize the mouse to the user’s specific desires. With the SteelSeries Engine and illumination present on the design, the Sensei has a new look, both on the outside and on the inside. At the same time though, the Sensei still retains all the features that the original Xai is known for such as its ambidextrous design, the ability to save different profiles on board, and the LED panel to customize the
mouse on the fly.
- Programmable macro buttons
- Ambidextrous shape
- Driverless plug-and-play
- User defined bitmaps for the on mouse LCD
- SteelSeries ExactSens
- SteelSeries FreeMove
- Menu system on the mouse
- SteelSeries ExactAim
- 7 Programmable buttons
- SteelSeries ExactLift
- Gold-plated USB connector
- 16 million colors of illumination
- Three zone lighting
- Scroll Wheel
- CPI Indicator, and Logo
Only £62.99 inc VAT.
ORDER NOW
NZXT H2 Classic Silent Midi Tower Case - Black @ £66.98 inc VAT
NOISE – chaotic wavelengths that distract, distort, impede, confuse, and endanger the gamer during a life and death situation. Intelligently constructed to give you peace of mind, NZXT’s H2 Classic Series Silent Midtower Chassis minimizes extraneous hums, clicks, whirls of your system to enhance your concentration, accuracy, and deadliness.
- Touch powered fans with fan filter for easy maintenance and fan swapping
- 30W 3-step fan control for airflow settings at 40%, 70%, and 100% of maximum fan speed
- Top hot swap capable SATA HDD Dock (requires an AHCI capable motherboard and hot swappable HDD) and USB 3.0 port for the most up to date function
- 8 Front facing HDDs for optimal airflow
- Noise dampening foam and a top magnetic fan cover for minimal PC noise
- Ample 25mm space behind motherboard for cable management
- Dimensions: 215 x 466 X 520 mm
- VGA Clearance Maximum: 310 w/o HDD, 250mm with HDD
- CPU Heatsink Support: 170mm
- Front Cooling: 2 X 120mm @ 1200rpm ( included )
- Rear Cooling: 1 X 120mm @ 1200rpm (included)
- Top Cooling: 1 X 140mm
- Bottom Cooling: 1 x 120mm
- Drive Bays: 3 x external 5.25" & 8 x Internal 3.5"/2.5" Slots
- Screwless Rail Design
- Expansions Slots: 7
- Motherboard Support: ATX, MICRO-ATX, BABY AT
Only £66.98 inc VAT.
ORDER NOW
