CM Storm Scout II Advanced Gaming Case - Gun Metal @ £64.99 inc VAT
CM Storm Scout 2 Advanced is the upgraded edition of Scout 2. It supports up to 9 fans, including two pre-installed 120mm red LED fans in the front for optimized cooling. It features improved steel reinforced carrying handles, bolted to the core structure. The top console has been upgraded to USB 3.0 for high power charging and lightning fast file transfers, and can be hidden and protected from dusty battlefields, friendly fire and melee attacks behind a slide cover. The 1st HDD cage can be removed, to support monster VGAs like the NVIDIA GTX 690 and AMD HD 7990, turning it into a powerful Battlestation.
- Ergonomic steel reinforced carrying handles
- Dual USB 3.0 support for 10x faster file transfer and high current smart phone / tablet charging (~1A)
- Supports up to 3 ODDs (tool-less), 7 HDDs and 4 SSDs for increased expandability
- Supports up to 9 fans, including two 120mm fans on the acrylic side panel window
- Two pre-installed 120mm red LED fans behind the front mesh panel for optimized airflow
- Top panel LED switch to disable the LEDs of front LED lit case fans at night
- Supports all high-end graphics cards up to 399mm / 15.7 inch with the 1st HDD cage removed
- Dust filters for PSU (slide out) and front panel
- Materials: Appearance: Polymer, Coated Steel Mesh and Body
- Dimensions (W x H x D): 230 x 513 x 517.5mm / 9.1 x 20.2 x 20.5 inch
- Net Weight: 8.56 kg / 18.87 lbs
- Motherboard Type: Micro-ATX, ATX
- 5.25" Drive Bays: 3 (exposed)
- 3.5" Drive Bays: 7 (hidden)
- 2.5" Drive Bays: 4 (converted from 3.5" drive bays)
- I/O Panel: USB 3.0 x 2 (int.), USB 2.0 x 2, Mic x 1, Audio x 1 (supports AC97 / HD Audio)
- Expansion Slots: 7
- Cooling System: Top: 120mm fan x 2 (optional)
- Front: 120mm red LED fan x 2 (with LED on/off function)
- Rear: 120mm black fan x 1
- Bottom: 120mm fan x 1 (optional)
- Side: 120mm fan x 2 (optional)
- HDD cage: 120mm fan x 1 (optional)
- Power Supply Type: Standard ATX PS2
- Maximum Compatibility: VGA card length: 287mm / 11.3 inch (with HDD cage); 399mm / 15.7 inch (without HDD cage)
- CPU cooler height: 162mm / 6.4 inch
Only £64.99 inc VAT.
ORDER NOW
_____
Acoustic Energy Aego M 2.1 Speaker System - Black @ £114.95 inc VAT
The Aego M-System builds on the strengths of the award winning Aego 2, offering a pair of heavy-alloy satellite speakers and a compact subwoofer for a full range sound that embodies AE’s sound quality principles. The sleekly styled satellites have smoother treble and a funky rounded design while potent amplifiers are built into the subwoofer to drive all three loudspeakers. The package gives room-filling sound from devices like the iPod™, PSP™ or MP3 mobile phones. With just one cable the M-System turns any personal music device into the heart of a home entertainment system. In the living room, in the bedroom, away at college or simply for a spontaneous party, the M-System delivers a big sound form the smallest devices. Better still, the M-System’s gorgeous looks, high quality sound and plug and play simplicity won’t cost a fortune as it remains just as affordable as the best selling AE Aego 2.
- Easy to setup and use
- Hi-fidelity, high volume sound
- Instant home entertainment
- Big hi-fi sound from the smallest devices
- Outstanding value for money
- Inputs: 3 x RCA Phono - Line level, 1 x Stereo Mini jack - Line level
- Outputs: 3 x Speaker terminals
- Controls: 1 x Volume / Power pot, 1 x Bass switch (3 Position), 1 x Centre input switch (2 Position)
- Power ratings: 120V Model - 120V @ 60Hz; 80VA, 240V Model - 240V @ 50Hz; 80VA, 90 Watts RMS total system power rating
- Frequency response: Sub is 50Hz-250Hz and the satellites are 250Hz-16KHz
- Dimensions: Sub Woofer - 265 x 190 x 350mm, Satellites - 68mm x 103mm x 90mm
- Weight: 9 Kg
Only £114.95 inc VAT.
ORDER NOW
ORDER NOW
_____
- Weight: 9 Kg
ORDER NOW
