**Today Only 06/06/2013** Antec 302 Three Hundred Two Ultimate Gaming Case & MSI GeForce GTX 660 OC
22 Aug 2010
Snap up some today only deals. The Antec 320 hits a great price point with a £15 saving, an all around decent case. You can also get the MSI GeForce GTX 660 OC Twin Frozr 2GB graphics at a reduction today, play in great detail for only £159.95! saving you a nice sum of £20
Antec 302 Three Hundred Two Ultimate Gaming Case - Black @ £44.99 inc VAT
The team that brought you the Three Hundred is back with an enclosure designed to handle today and tomorrow's high-performance systems. Introducing the Three Hundred Two, the next standard in affordable gaming cases. Our newest chassis is built for gamers from the inside-out, from its aggressive front bezel, to its advanced cooling system. With tool-less 5.25" & 3.5" drive bays, a large cable management compartment and two front panel USB 3.0 ports with an internal connector, the Three Hundred Two is the rightful heir to the Gaming Series legacy.
- 11 drive bays:
- 3 x 5,25" tool-less drive bays
- 2 x 2,5" drive bays (dedicated)
- 6 x 3,5" tool-less drive bays
- Motherboards: Standard ATX, microATX, Mini-ITX
- 8 expansion slots
- Maximum graphics card size: 318 mm (12,5")
- Maximum CPU cooler height: 170 mm (6,7")
- Rear Cooling: 1 x 120 mm rear TwoCool fan
- Top Cooling: 1 x 140 mm top TwoCool fan
- Front Cooling: 2 x 120 mm front intake fans (optional)
- Side Cooling: 1 x 120 mm side intake fan (optional)
- 1 x 120 mm side exhaust fan behind motherboard (optional)
- Perforated front bezel for maximum air intake
- Water cooling support: top water cooling grommets
- Enlarged CPU cutout
- Front I/O ports: 2 x USB 3.0 with internal motherboard connector / Audio In/Out
- Unit Dimensions: 513 mm (H) x 229 mm (W) x 471 mm (D)
Only £44.99 inc VAT.
ORDER NOW
MSI GeForce GTX 660 OC Twin Frozr 2048MB GDDR5 PCI-Express Graphics Card @ £159.95 inc VAT
This MSI GTX 660 OC Twin Frozr is massively over-engineered and is using a superior cooler to what is found on reference GTX 680's as such this is the fastest out of the box GTX 660 we sell and has superb overclocking potential. Yet even with all this performance you can still game in near silence.
NVIDIA launched a new era in gaming with the NVIDIA® Kepler™-powered GeForce GTX family. Now, there are two new ways to experience the fastest, most efficient and powerful generation of graphics cards for yourself. Take your gaming experience to the next level with the GeForce® GTX 660-the weapon of choice for gamers-or the powerful yet remarkably priced GeForce GTX 650. Choose your weapon. Game on!
Specification:-
- Core Clock: 1033MHz (GK104)
- Core Boost Clock: 1098MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 960
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 2-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 130 watts at stock speed)
- 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £159.95 inc VAT.
ORDER NOW
What's the performance like. I mean in SLI what would this rate too? What a 780 or higher?
I'd say similar to a 680 / 7970. Have a look at the 3dmark11 scores in the Graphics forum.
Simple and functional great stuff. Gives a good option for people looking to do budget builds.
The Antec case is a very good offer for this price on a budget so long as you take good care of cable management.
Btw good job with the extra photos to show it fits a couple HD6990s (?) from the appearance of the PCIe 8+8-pins - max length is 31.8 cms clearance for GPU whilst the HD6990 is 30.5 cms total length. Not the longest card as that is the HD5970 Black Edition at 12.2 inches which is 31 cms but you require additional room for exhausting that air and this case does slightly better than even the more expensive Corsair 300R. Bar the smaller grommets on the 302 vs the 300R I own, this would be a good alternative so long as you install a front intake fan and add another sidepanel fan for the GPU/s.
And a deal so good it was posted twice...
