**Today Only 06/07/2012** Hazro HZ27WC 8-Bit 27" LED Pro Monitor & Razer Tiamat Elite 7.1 Surround S
22 Mar 2011
Cheshire
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Monitor - Black @ £339.95 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WC features the same high resolution LED IPS panel found in the HZ27WA without scaling functionality. Video content bypasses scalers making the HZ27WC ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 1000:1 / 1,000,000:1 (Dynamic)
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x Dual Link DVI-D
- 2.5mm Audio out
- Kensignton Security Port
- 8bits [16.7Million colors]
- Dual Link DVI-D Cable, 2.5mm Audio Cable, 24V External Power Adapter, UK
- PIP/POP, Mapping: Not Supported
- 3yr RTB Warranty (UK customer only)
Was £389.99 Inc. VAT
Only £339.95 Inc. VAT[
ORDER NOW
Razer Tiamat Elite 7.1 Surround Sound Analog Gaming Headset **UK EXCLUSIVE** @ £149.98 inc VAT
Behold the Razer Tiamat 7.1, the world's first circumaural gaming headset with 10 individual drivers built-in to deliver the ultimate 7.1 Surround Sound experience. Dominate deathmatches when you can hear incoming enemy footsteps to prevent backstabs and pinpoint enemy locations through gunfire with absolute precision. No other surround sound headset has been engineered to produce such lifelike positional audio geared for the ultimate tactical advantage.
Total audio mastery in your hands. Set the volume, audio positioning and bass depth as you want via the audio control unit. Whether it’s configured to blast a full frontal wall of sound or scaled down to simple stereo, get the right level of intensity for your gaming audio every time.
7.1 surround sound with lifelike positional audio
A world’s first, the 10 individual drivers in the Razer Tiamat 7.1 provide immersive, crystal clear surround sound. The reproduced audio is so rich and lifelike that not only will you feel like you’re right there, you’ll have the edge over your enemies. Let ‘em try sneaking up on you now.
Full audio customization
Easily and accurately fine-tune the level of each audio channel, position, and bass depth to your exact enjoyment using the supplied control unit.
Maximum comfort, maximum durability
The Razer Tiamat 7.1’s sturdy construction and padded leatherette ear cups ensure extended headset life and ultimate comfort so you can keep going during those hardcore marathon gaming sessions.
• True-to-life 7.1 Surround Sound from 10 discrete drivers
• All-in-one volume control unit for multi-channel customization and toggling between headset and speakers
• Comfortable, snug fit for extended play
• Retractable, noise-filtering unidirectional mi
• Interchangeable ear cup covers
• Replaceable soft-touch leatherette ear cushions
• Braided fibre cable
• PC with built-in 3.5mm audio jacks & 1 USB port
• 7.1 Surround Sound-enabled Sound Card (for 7.1 Mode)
Was £159.98 Inc. VAT
Only £149.98 Inc. VAT
ORDER NOW
How robust are the joints on the ear cups to the headband?
On my Logitech G35, they broke on both sides, had to use glue and tape -_____-
Surprised the headset haven't all gone already, maybe everyone who wanted one, like me, have them :O. Or they are all stuck at work :P
probably all at work. the majority of our today only sales tend to take place in the evening as thats when most people browse the site :)
