Today's deal!
The 680 deals is flippin mental! So make sure that you get onto that one!
MSI GeForce GTX 680 Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
This MSI GTX 680 Power Edition is almost identical to the record winning MSI GTX 680 Lightning, but here at OcUK we consider this card to be even better than the Lightning for two main reasons. The first being that this card cost far less, but the second that this card has Dual DVI connectivity.
Very limited stock and a crazy price!
Features:-
- GPU Reactor
- Xtreme Thermal
- Military Class III Components
- Triple Overvoltage: adjust the voltage of GPU, memory and VDDCI to unleash the potential of graphics card
- Offer 16 degree cooler and 6.7dB quieter than reference product
- Enhanced PWM Design: provide higher overclocking capability and better stability in peak load
Specification:-
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1084MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2038MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x Dual-Link DVI-I, 1x DVI, 1x HDMI & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Card Dimensions: 270*111.15*38.75 mm
- 2x 8-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £259.99 inc VAT.
ORDER NOW
Enermax ELC120-TA Liquid Cooler with 2x T.B.Apollish Blue 12cm Fans (Socket 775 / 1155 / 1156 / 1150 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £57.85 inc VAT
Maintenance-free Cooling System
All-in-One liquid CPU cooler with pre-filled coolant offers best usability and maximum cooling performance for powerful PC systems.
Tri-Cooling Mode
High-performance PWM fans with innovative speed range switch for an individual RPM according to the system requirements: Silent Mode (800-1,500 RPM), Performance Mode (800-1,800 RPM) & Overclock Mode (800-2,200 RPM).
Long-Life Pump
Pump with durable ceramic bearing for reliable and noise-less performance.
Flexible & Robust Tubes
High-quality tubes made of FEP (Fluorinated Ethylene Propylene) guarantee non-permeable and long-lasting operation.
Easy & Universal Mounting System
User-friendly and quick mounting system giving perfect contact force with the CPU. Full support of all latest AMD® and Intel® sockets.
1x Liquid CPU Cooler ELC120-TA/-TB
2x T.B.Apollish blue 12cm fans (only ELC120-TA)
2x T.B.Silence 12cm fans (only ELC120-TB)
1x Intel® CPU Bracket
1x AMD® CPU Bracket
1x Back Plate
4x Back Plate Nut
4x Bracket Screw
4x Bracket Screw for Intel® LGA 2011 socket
8x Fan Screw
4x Case Screw
8x Rubber Pads
1x Installation Guide
Only £57.85 inc VAT.
ORDER NOW
Features:-
- GPU Reactor
- Xtreme Thermal
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Tri-Cooling Mode
Long-Life Pump
1x AMD® CPU Bracket
1x Back Plate
4x Back Plate Nut
4x Bracket Screw
8x Fan Screw
4x Case Screw
8x Rubber Pads
ORDER NOW
