* Today Only 06/10/2010 * Gigabyte GeForce GTX 460 OC £164.49! & Samsung 2TB £76.36
22 Aug 2010
For Today Only, Power your games with the Gigabyte GeForce GTX 460 OC 1024MB Graphics card or save thousands of files, movies, photos and many more on the Samsung SpinPoint F3 EcoGreen 2TB. Great deals, amazing prices. Dont miss out!
Gigabyte GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card @ £164.49 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
The special inclined dual fan design effectively minimizes the flow of turbulence between two fans and enhances heat dissipation of hot area right underneath each fan. By unique design, WINDFORCETM 2X even enlarges air channel on the graphics card vents and creates a more effective air flow system in chassis. This special design helps heat dissipate quickly from GPU. In addition, WINDFORCETM 2X is equipped with 2 copper heat-pipes which strengthen the speed of heat dissipation.
Features
- Core Clock: 715Mhz
- Memory: 1024MB GDDR5
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1430MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1xHDMI & 1 X Analogue
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Only £164.49 inc VAT.
ORDER NOW
Samsung SpinPoint F3 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD203WI) @ £76.36 inc VAT
Samsung’s F3 Series EcoGreen Drive (F3EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F3EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F3 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F3EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F3EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Only £76.36 inc VAT.
ORDER NOW
I made this jump to GTX460 just the other week and have been impressed. Wasn't sure how much of an improvement I'd really see but it's worth it.
I had to step a few games back to 1680x1050 on the 260 and even then I coudn't use max settings. Like to dabble with Arma2 and it struggled a bit.
Since the upgrade it's been 1920x1200 and pushing max settings in the few games I've tried. Nice and quiet too as was my Sparkle GTX260.
