**Today Only 06/12/2011** XFX Pro 850W Core Edition '80 Plus Bronze' PSU & LG BH10LS38 10x BluRay-RW
22 Aug 2010
Two fantastic pieces of hardware on Today Only. Deal stock is limited so don't miss out!
XFX Pro 850W Core Edition '80 Plus Bronze' Power Supply @ £74.99 inc VAT
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which, along with XFX’s new EasyRail™ Technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail™ optimizes it all for you. Available in 650W, 750W and 850W, XFX ProSeriesPSUs with EasyRail™ Technology gives you one continuous rail of power covering the total maximum wattage. EasyRail™ Technology Provides Maximum Power Unique, continuous EasyRail™ technology enables you to maximize available power and makes set-up easy.
- Fixed FDD: 1
- Fixed Peripheral: 7
- Fixed 6+2-pin PCI-E: 2
- Fixed 6-pin PCI-E: 2
- Fixed ATX12V / EPS12V: One 4+4-pin
- Fixed Motherboard Connector: 20+4 Pin
- Fixed SATA: up to 11
Only £74.99 inc VAT.
ORDER NOW
LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black (OEM) @ £64.98 inc VAT
Read and write Blu-ray discs at 10x with the BH10LS38 Blu-ray rewriter that allows you record files, photos, or business documents onto a single dual layer BD-R Blu-ray disc. Play HD content from BD Video discs or record up to nine hours of high definition video. SATA interface technology allows for easier integration and ultimately faster performance while LightScribe gives you the added feature of etching customized labels onto a special coated LightScribe discs. Get into the Blu with the BH10LS38 by LG.
Write Speeds
- BD-R: 10x
- BD-RE: 2x
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 10x
- BD-R: 6x
- BD-R: 6x
- BD-RE: 8x
- DVD-ROM:16x
- DVD-R: 12x
- DVD-RW: 10x
- DVD+R: 12x
- DVD+RW: 10x
- DVD-RAM: 5x
- DVD-Video: 8x
- CD-R/RW/ROM: 40x
- CD-DA: 40x
- 80 mm CD: 16x
Only £64.98 inc VAT.
ORDER NOW
Does the BR Writer come with a software bundle?
I know OEM generally don't but it appears some BR drives do come with software.
now that bluray is becoming affordable-ish BD-R could be an alternative for backing up or storing your data while hard drive prices are so high :) 25GB a disc isn't bad.
