Looking to watercool your PC? now is the chance to pick up our specialist OcUK Tech Lab - V12 Watercooling Kit 360 **2011 Compatible** with a £20 saving. It is complete with everything you need to cool your PC with maximum efficiency.
Putting an SSD into your system will dramatically decrease boot times and increase the performance of your system. Instant media browsing, faster game loading times will ensure you spend more time playing and less time waiting.
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) @ £116.99 inc VAT
nonl2brAs the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 500MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £116.99 inc VAT.
ORDER NOW
OcUK Tech Lab - V12 Watercooling Kit 360 **2011 Compatible** @ £259.98 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX360 120mm Radiator - Black
Offering superb performance, build quality and value the XSPC EX range of radiators are the obvious choice for high end watercooled systems.
1X 12V Alphacool Laing D5 Vario Pump 655
The best watercooling Pump on the planet. Accept no substitutes.
1X Alphacool HF D5 TOP - Black Acetal G1/4
A powerful aftermarket top to ensure maximum performance from your D5 Pump
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
1X Phobya Single Bay Reservoir - Multi Fascia
A high flow reservoir for your D5 providing an easy filling and draining point in your loop.
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Ultra Pure H20 Watercooling Fluid
The purest water available - ensuring the best temperatures.
2X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
This kit can also be upgraded with an additional VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Please ask our friendly sales team for VGA block advice.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £259.98 inc VAT.
ORDER NOW
- Capacity: 120GB
- Warranty: 3 Years
ORDER NOW
Component List:
IMPORTANT:
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
ORDER NOW
