Today Only Deals!
Surge Protected Power Centre with 8 Socket/LAN Port/Telecom/Modem/Broadband Protection - 2 Metre @ £13.98 inc VAT
Fellow gamers and enthusiasts know of the heartache when your precious computer is out of action. So why not do all that you can to prevent outtages due to damaged hardware. Well now for an amazingly low price you can have the peace of mind that you are protected against electricial surges and spikes.
Hundreds of power surges can occur in your home or office everyday. The switching on and off of lights and household appliabces like refridgerators, washin machine and tuimble dryers can cause surges. Most warranties do not cover power surge damage, and these surges and spikes can cause serious damage to your electronic hardware. Even low energy surges and spikes can cause gradual component degradation leading to hardware failure. The manufacturer MasterPlug are that confident in their technology that this MasterPlug product comes with a 'connected equipment warranty'. In the unlikely event that a surge passes through this device and any damage occurs to your hardware, MasterPlug will pay up to £3000 for the replacement equipment*.
- Surge protection for your home office and PC equipment: computers, fax machines, scanners, routers, from damaging surges and spikes.
- 8 Surge protected power sockets with three channel protection & safety thermal cut-out
- Power & surge neon indicators. LAN/Ethernet Surge protection. All necessary leads supplied.
- Telecom/Modem/Broadband connection surge protection with telecom splitter provides protection for two devices from one input.
- £3,000 connected equipment 3 year warranty for peace of mind*.
* Subject to warranty registration online at the time of purchase.
Only £13.98 inc VAT.
ORDER NOW
OcUK Tech Lab - V12 Watercooling Kit 360 @ £180.00 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX360 120mm Radiator - Black
Offering superb performance, build quality and value the XSPC EX range of radiators are the obvious choice for high end watercooled systems.
1X XSPC D5 Dual Bay Reservoir/Pump Combo
The worlds best watercooling pump mounted to a high performance, stylish reservior. This is the ultimate choice for a tidy system with easy to fit and fill internals.
1X XSPC Raystorm [Choose your socket type from the drop down menu]
The most advanced high performance CPU waterblock on the market. LED customisation and astounding flow rates make this perfect.
3X Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Coolant
Pick your own coolant that suits your taste and style
2X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
This kit can also be upgraded with an additional VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Supported sockets with Intel Block
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Supported sockets with AMD Block
- AMD AM2 Socket
- AMD AM2+ Socket
- AMD AM3 Socket
- AMD FM1 Socket
- AMD FM2 Socket
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £180.00 inc VAT.
ORDER NOW
ORDER NOW
Component List:
1X Mayhems Coolant
IMPORTANT:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD AM2 Socket
- AMD AM2+ Socket
- AMD AM3 Socket
- AMD FM1 Socket
- AMD FM2 Socket
***NOTE***
ORDER NOW
