**Today Only 07/03/2012** Compro VideoMate DVB-T100 Digital TV & Samsung Green 8GB 30nm 1600MHz Memo
22 Aug 2010
Today Only we feature a worlds first 30nm memory kit, the benefits being low-power and huge OC potential with the Samsung Green 8GB DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit.
We also have a Compro VideoMate T100 PCI-E card, more information below :)
Compro VideoMate T100 is an advanced silicon digital TV tuner card with Philips 9-bit ADC chip and low-profile card design to provide free-to-air HDTV quality digital terrestrial TV reception. VideoMate T100 accompanied by Compro Picture Purifying Technology to brings a world of enhanced TV services directly to your PC, turning your computer into a home entertainment center.
Compro VideoMate DVB-T100 Digital TV Internal PCI - Retail @ £18.48 inc VAT
- Watch Free-to-Air DVB-T digital TV shows on your PC
- Silicon digital TV tuner with Philips 9-bit ADC chip
- Supports SDTV and 1080i HDTV (where available)
- Advanced PIP/POP features up to 4 sub channels watching
- Video Desktop to setup the live TV screen as wallpaper
- Customize Brightness, Hue, Saturation, Contrast, and audio selection in each TV channel
- Digital TV supports MPEG-2 and Transport Stream recording/playback
- Capture analog video from S-Video to digital files
- Analog video capture supports MPEG-1/2/4 formats recording
- Analog video capture supports pause while recording and automatic spilt file size
- Timeshifting, channel surfing, and still frame capture
- Supports audio and language selection in available channels
- Supports EPG, subtitle and Teletext (where available)
- Fully functional IR remote control for TV and DVD playback
- Microsoft BDA driver
Only £18.48 inc VAT.
ORDER NOW
Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit (MV-3V4G3D/US) @ £59.99 inc VAT
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB).
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
Features:-
- Model Name: MV-3V4G3D/US
- Main Board: INTEL/AMD
- System: DESKTOP/SFF
- System Type: DDR3
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets
- CAS Latency: 11-11-11-28 1N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1600 (PC3-12800)
- Test Voltage: 1.25-1.55V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM Low Profile
- Warranty: Lifetime
Overclocking Features (Not Guaranteed)
- 1600MHz (7-8-8-24 1N) @ 1.40v
- 1866MHz (9-9-9-27 1N) @ 1.40v
- 2000MHz (9-10-10-28 1N) @ 1.45v
- 2133MHz (10-10-10-28 1N) @ 1.45v
- 2400MHz (11-11-11-28 2N) @ 1.50v
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M
Only £59.99 inc VAT.
ORDER NOW
What time do the weekly specials go up? Wondering how long I have left to order a u2711 at the special price.
