Hi Guys
we have two superb products for this weekends deals.
The awesome HAF X chassis from Coolermaster gives you immense airflow and is brimming with watercooling potential.
Second up, is the Razer DeathAdder. This mouse is a game changer and is designed to help you win!
Both of these items are at brilliant price points, offering you great deals throughout this bank holiday weekend!
Cooler Master HAF X Gaming Tower Case - Black (RC-942) @ £129.98 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Base Mounted PSU Bracket
Was £139.99 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Razer DeathAdder Respawn 3500 DPI Xtreme Precision Gaming Mouse - Retail @ £44.99 inc VAT
The Razer DeathAdder is the weapon of choice for gamers seeking a combination of comfort and unbridled gaming precision. Enjoy extended gaming sessions in comfort with its right-handed ergonomic form factor crafted for the world of competitive gaming; and when the difference between victory and defeat is determined between heartbeats, the 3500dpi Razer Precision 3.5G infrared sensor translates your every movement into frags with pinpoint accuracy.
- 3500dpi Razer Precision™ 3.5G infrared sensor
- Ergonomic right-handed design
- 1000Hz Ultrapolling™ / 1ms response
- Five independently programmable Hyperesponse™ buttons
- On-The-Fly Sensitivity™ adjustment
- Always-On™ mode
- Ultra-large non-slip buttons
- 16-bit ultra-wide data path
- 60–120 inches per second and 15g of acceleration
- Zero-acoustic Ultraslick™ Teflon feet
- Gold-plated USB connector
- Seven-Foot, lightweight, braided fiber cable
- Approximate size: 128mm (length) x 70mm (width) x 42.5mm (height)
Was £54.98 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
- PCI Slots: 9
ORDER NOW
- Always-On™ mode
Was £54.98 Inc. VAT
ORDER NOW
