Corsair Flash Voyager Slider X1 64GB USB 3.0 Flash Drive (CMFSL3X1-64GB) @ £19.98 inc VAT
Flash Voyager Slider X1 is a compact USB 3.0 drive with bold styling and performance to match its looks. It has a smart design, with a USB connector that retracts for protection when you’re not using it. A blue activity LED tells you at a glance if it’s transferring data.
It’s also universally compatible with Windows, Mac OS X and even Linux, with no driver necessary. It supports high-speed USB 3.0 transfers along with full USB 2.0 compatibility, so you can use it with virtually any desktop or notebook.
Features:
Convenient, compact size - It’s easy to take with you, everywhere you go.
Capless design - The USB connector retracts when you’re not using it, and you don’t need to worry about misplacing a cap.
Blue activity LED - Check whether your drive’s busy transferring data at a glance.
High-speed USB 3.0 performance with USB 2.0 compatibility - Great performance on the latest systems, and it still works on virtually any system out there.
5 years warranty - Peace of mind. A statement of Corsair product quality and reliability.
Technical Specs:
Unformatted Capacity : 64GB
Max Sequential Read (CDM) : Up to 130MB/s
Interface Type: USB 3.0, USB 2.0 compatible
Only £19.98 inc VAT.
ORDER NOW
______
Crucial BX100 500GB SSD SATA 6Gbps 7mm Solid State Drive (CT500BX100SSD1) @ £134.99 inc VAT
Free 16GB USB Flash drive for putting your OS installation on to for quicker installation
Boot up almost instantly. Load programs in seconds. And accelerate demanding applications with ease. It all starts with ditching your hard drive.
The storage revolution that started in 2008 with our first SSD continues with the new Crucial® BX100. Engineered to outperform a hard drive and deliver cost-effective performance, the Crucial BX100 leverages advanced flash memory technology and moves your computer beyond the outdated storage limitations of spinning discs. By transmitting data in a digital manner rather than having to seek it out on a spinning platter, the Crucial BX100 makes nearly everything on your computer faster and more efficient.
Over 15x faster than a typical hard drive
Get more done in less time – or just have more fun. The Crucial BX100 SSD is over 15 times faster than a typical hard drive and delivers true 535 MB/s sequential reads on both compressible and incompressible data. By treating all data the same, the Crucial BX100 allows you to do everything quickly, regardless of whether you’re saving an image, accessing a ZIP file, or loading a video.
Over 2x more reliable than a typical hard drive
Protect your data by storing it on the Crucial BX100, which is significantly more reliable than a typical hard drive. In the computer industry, storage drive reliability is measured in mean times between failures (MTBF). Most hard drives have MTBF ratings of 0.6 million hours, whereas the Crucial BX100 has a reliability rating of 1.5 million hours. In practical terms, the more reliable your drive is, the less likely it is to crash.
Nearly 2x more energy efficient than a typical hard drive
Run your system longer and harder – using less power. With Extreme Energy Efficiency technology, the Crucial BX100 is over 90% more energy efficient than a typical hard drive. Since SSDs access data digitally rather than seeking it out on a spinning platter, they consume significantly less power.
Better value than a typical SSD
Get more out of your system – without compromising quality. At speeds up to 535 MB/s, the Crucial BX100 SSD isn’t the fastest drive on the market, but that’s squarely our intent. We painstakingly engineered the Crucial BX100 to provide a massive performance boost, while also delivering an unrivaled value among SSDs. Make the switch to the Crucial BX100 and get everything you expect from a Crucial SSD at an unexpected value.
Specifications:
Sequential Read MB/s: 535
Sequential Write MB/s: 450
Random Read IOPS: 90k
Random Write IOPS: 70k
Only £134.99 inc VAT.
ORDER NOW
Features:
Technical Specs:
ORDER NOW
______
Specifications:
ORDER NOW
