**Today Only 07/05/2012** Cooler Master Elite 430 Case & Titan 8000a Krypt Gaming System
22 Aug 2010
Today Only deals!!
Cooler Master Elite 430 Windowed Case - Black @ £34.98 inc VAT
The Elite 430 Black was designed all-black interior coating with its main purpose in mind as such there’s plenty space for large graphics cards, no matter your brand preference. The Elite 430 Black also features plenty of cooling options and a well ventilated front mesh design to keep even the hottest system nice and cool.
- Interior black coating makes stylish inside looks
- Front 120mm fan with brilliant Blue LED provides the best airflow to HDDs
- Rear 120mm fan for high-efficiency ventilation
- Tool-Free mechanical design for quick assembly and maintenance
- Side ventilation holes for better cooling performance
- Large transparent side window included
- Supports long graphics cards including Radeon HD 5970
- Top Cooling: 120 mm fan x 2 (optional)
- Front Cooling: 120 mm blue LED fan or 140 mm fan x 1 (optional)
- Rear Cooling: 80/90/120 mm fan x 1(optional) (120mm fan included)
- Side Cooling: 120 mm fan x 1(optional)
- Bottom Cooling: 80/90/120 mm fan x1(optional)
- I/O Port: USB 2.0 x2, Mic x1, Audio x1, 1394a x 1,(optional)
- Dimension: 190 x 424 x 490 mm (W x H x D)
Only £34.98 inc VAT.
ORDER NOW
"Titan 8000a Krypt" AMD Bulldozer 3.60GHz Quad Core System @ £485.35 inc VAT
The "Titan 8000a Krypt" features a AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
Why Should You Buy This System?
- Includes the superb AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor
- Choose from a selection of graphics cards to meet your performance needs
- 8GB of high performance gaming memory guarantees the smoothest possible experience when multitasking and ensures you never have a break in the action
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: Antec 300 Gaming Case (default choice, options available)
- Power Supply: OCZ ZS 650w PSU
- CPU: AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor
- Motherboard: AMD 760G Chipset (AM3+) Motherboard
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drives: 1TB HDD
- Graphics Card: AMD 760G Onboard (default choice, options available)
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
- Cooling: x2 White LED 120mm Fans
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
If your after the latest in AMD technology then this system is for you. Quad core technology and DDR3 performance at an excellent price point.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £524.95 inc VAT.
Only £485.35 inc VAT.
ORDER NOW
"- Includes the superb AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor"
Should be reporting you to the trading standards for that :p
