**Today Only 07/05/2013** OcUK Tech Labs - Metal Keycaps Arrow Keys & Kingston HyperX Genesis Blue 8
22 Aug 2010
Need to add that extra ounce of swag to your gaming setup? Rig all sorted and looking mean?
Don't worry because now you can pimp your keyboard's arrow keys with our special today only deal. Replace your mechanical keyboards arrow keys and silver plate them up for ultimate gaming experience.
The kingston memory is THE LOWEST PRICE IN THE UK!!!!!!
OcUK Tech Labs - Metal Keycaps Arrow Keys - Silver @ £3.98 inc VAT
Fragging with style! Mechanical keyboard like the Zowie/Corsair/Steelseries/Ozone and Qpad range are defined by the high quality Cherry MX Switches. But have you ever stopped to look at the key caps. Some are inferior. They will of course stand the test of time, but can look pretty boring! Well now they do not have too, you can replace them with high quality metal keycaps which will improve the feel and quality of your already high end keyboard.
- Number of buttons: 4
- Keyset: arrow keys
- Colour: Silver
- Weight: 5.44 g
- Material: Zinc Alloy
- Finish: electroplated
- Surface Protection: UV coating
- Caption: Laser
- Compatibility: Mechanical keyboards with Cherry MX switches
Only £3.98 inc VAT.
ORDER NOW
Kingston HyperX Genesis Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3K2/8GX) @ £41.99 inc VAT
Kingston's KHX1600C9D3K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £41.99 inc VAT.
ORDER NOW
