**Today Only 07/06/2013** Sapphire HD 7870 GHz Edition 2048MB Gfx & Alpenföhn K2 Mount Doom CPU Cool
22 Aug 2010
Two great products today with a price drop for even more convenience. The Alpenföhn K2 Mount Doom CPU Cooler will fit your Haswell system, so you'll be able to get nice overclocks and keep the CPU at good temps.
Sapphire HD 7870 GHz Edition 2048MB GDDR5 PCI-Express Graphics Card (11199-16-20G) @ £179.99 inc VAT
The new SAPPHIRE HD 7800 series of graphics cards is based on the third family of GPU’s from AMD built in its new 28nm process and featuring the highly acclaimed GCN graphics processing architecture.
The Sapphire HD 7870 GHz Edition is equipped with 2GB of the latest GDDR5 memory clocked at 1200MHz (4.8Gb/s effective) with the new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Features:-
- Core Clock: 1000MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1280
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 Single Link DVI, 1 HDMI & 1x DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Only £179.99 inc VAT.
ORDER NOW
Alpenföhn K2 Mount Doom CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £49.99 inc VAT
nonl2br
For ages myths and legends surround one of the scariest mountains on earth. Icy winds and heavy snow fall had been the reason all attempts to reach the crest failed …<br>
You might not be surprised that the K2 inspired us to choose the name for our latest creation. By using 8 Heatpipes in a twin tower design, dual wing boost configuration and MnTal-Airflow Technology the new Alpenföhn K2 reches highest performance at lowest noise.<br>
<br>
Twin tower with 8 x 6mm Heatpipes <br>
- The new Twin Tower Design can reach best results in noise and performance by using a combination of 2 fans.<br>
- The trapezoid finshape ensures better compatibility with VGA coolers by keeping the distance to the PCI-X Slot<br>
- All contact surfaces between Fins, Heatpipes and the baseplate are soldered.
Heatpipe/Baseplate<br>
- The U-Shape Heatpipes offer a large connection area to the baseplate for a better heat absorption
- By CNC machining the surface of the baseplate is perfectly even and the thermal transfer is optimized.<br>
Fins<br>
- K2 is the first cooler to feature the brand new Minimized noise Transfer at low Airflow-Technology. - The advanced finstructure influences the airflow through the heatsink to increase the heat transfer to the air.<br>
Wing Boost 120/140mm Dual-Combination<br>
- Equipped with integrated decoupling elements, WB technology and HD bearing K2 comes with each one 120mm and 140mm Wing Boost fans.<br>
<br>
120mm Fan<br>
- Fan Size: 120x120x25mm<br>
- Fan Speed: 1500 rpm<br>
- Airflow: 108 m³/h<br>
- Bearing: HD-Bearing(Hydraulic Bearing)<br>
140mm Fan<br>
- Size: 140x140x25mm<br>
- Fan Speed: 1100 rpm<br>
- Airflow: 104,7 m³/h<br>
- 2011 Compatibility requires additional mounting hardware
Only £49.99 inc VAT.
ORDER NOW
got me haribo today, turns out there was a cpu cooler the approximate size of a rabbit in the box, wonder if I should just go ghetto and fit it now and leave the side of the case off?
