**Today Only 07/08/2013** KFA2 GeForce GTX 660 EX OC 2GB & Corsair Hydro H80i High Performance Liqui
22 Aug 2010
Two stonking deals today, limited quantities on both so you'll have to be fast!
KFA2 GeForce GTX 660 EX OC 2048MB GDDR5 PCI-Express Graphics Card with a free copy of 3DMark advanced edition @ £143.99 inc VAT
The KFA GTX 660 EX OC comes with a massive overclock out of the box making it one of the best performing GTX 660's on the market and has already won the Hexus Recommended award. It also features a massively uprated cooling solution with two fans meaning even more overclocking potential and more or silent running even when under load.
NVIDIA launched a new era in gaming with the NVIDIA® Kepler™-powered GeForce GTX family. Now, there are two new ways to experience the fastest, most efficient and powerful generation of graphics cards for yourself. Take your gaming experience to the next level with the GeForce® GTX 660-the weapon of choice for gamers-or the powerful yet remarkably priced GeForce GTX 650. Choose your weapon. Game on!
Specification:-
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1072MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 960
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 2-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 130 watts at stock speed)
- 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
- Review: http://http//hexus.net/tech/reviews/graphics/44641-kfa2-nvidia-geforce-gtx-660-ex-oc/
Only £143.99 inc VAT.
ORDER NOW
Corsair Hydro H80i High Performance Liquid CPU Cooler (Socket LGA1155 / 1150 / LGA1156 / LGA1366 / LGA2011/ AM2 / AM3 / FM1 / FM2) @ £69.95 inc VAT
High-Performance CPU Cooling
Protect your hardware and increase your CPU’s overclocking potential. Dual fans and a double-thick radiator deliver outstanding cooling efficiency.
Advanced Fan Design
The 120mm fans use custom-engineered blades for better static pressure to noise ratio, offering improved performance at lower noise levels.
Corsair Link Monitoring and Control
Monitor temperature and control lighting and fan speed on your screen. No additional hardware is necessary.
Self-contained Cooling System
Hydro Series H80i comes pre-filled, and never needs refilling or priming.
Built-In Corsair Link
No additional hardware is necessary – just connect the included Corsair Link cable to a USB header on your motherboard and download the free Corsair Link Dashboard software. You can monitor coolant temperature and adjust cooling performance directly from your desktop.
Tool-free multiplatform magnetic mounting bracket kit
The modular design makes installation simpler, and it’s compatible with Intel and AMD processors.
Large-diameter, low permeability tubing
Minimal coolant evaporation helps ensure long life, and the resilient material offers both high flexibility and excellent leak protection.
• Corsair Hydro Series H80i High Performance Liquid CPU Cooler
• Magnetic Multi-platform mounting kit for all modern CPU sockets
• Dual SP120L High Performance Fans
• USB Cable for Corsair Link™ Compatibility
• Fan and radiator mounting screws
• Thermal compound (pre-applied)
• Quick Start Guide
• Technical Specifications
• Radiator dimensions: 120mm x 152mm x 38mm
• Fan dimensions: 120mm x 120mm x 25mm
• Fan speed: 2700 RPM
• Fan airflow: 77 CFM
• Fan dBA: 37.68 dBA
• Fan static pressure: 4mm/H20
Compatibility
• Intel™ LGA 1155, 1156, 1366, and 2011
• AMD™ sockets FM1, FM2, AM2, and AM3
Only £69.95 inc VAT.
ORDER NOW
