**Today Only 07/10/2011** Cooler Master Silencio RC-550 Silent Case & Razer DeathAdder Respawn 3500
22 Aug 2010
Today we have a sleek looking gaming case which is ideal for a silent system. With near silent operation and prepared to take on powerful hardware, the Cooler Master Silencio is able to keep high-end setups running cool and quiet.
The Razer DeathAdder Respawn is one of the most popular and widely used gaming mice in the world. We the ability to change the profiles to your liking and precision 3500DPI tracking an enemy will never be as much of a challenge!!
Cooler Master Silencio RC-550 Silent Tower Case - Black @ £59.99 inc VAT
Near silent operation and prepared to take on powerful hardware, the Cooler Master Silencio is able to keep high-end setups running cool and quiet. Sound proofing on both side panels assist in vastly reducing noise levels. A sleek mirror finish front panel and clean lines present a minimalistic design aesthetic that speaks to its silent interior. The benefits of elegance and silence, combined with the functionality of built in Super Speed USB 3.0, a multifunction SD card reader, and 3.5" X-dock HDD hotswap all make the Silencio a giant among its kind.
- Includes two 800rpm silent fans (Supports up to three 120mm fans)
- I/O panel provides easy access for users
- High quality foot stand
- Side ventilation holes for better cooling performance
- Dust Filter provided for easy access to wash
- Stylish and Simple design
- Dimensions: 210 x 415 x 505mm
- Motherboard Compatability: MicroATX & ATX
- 5.25" Drive bays x 3
- 3.5" Drive Bays x 7
- 2.5" Drive Bays x 1
- I/O Ports: USB3.0 x 1 / USB2.0 x 1 / Audio x 2 / SD Card reader
- Expansion Slots: 7
- Front Cooling: 120mm x 1, 800rpm silent fan pre-install (can fit 2 x 120mm)
- Rear Cooling: 120mm x 1, 800rpm silent fan pre-install
- Max CPU Cooler Height: 154mm
- Max GPU Length: 427mm
Only £59.99 inc VAT.
ORDER NOW
Razer DeathAdder Respawn 3500 DPI Xtreme Precision Gaming Mouse - Retail @ £49.98 inc VAT
The Razer DeathAdder is the weapon of choice for gamers seeking a combination of comfort and unbridled gaming precision. Enjoy extended gaming sessions in comfort with its right-handed ergonomic form factor crafted for the world of competitive gaming; and when the difference between victory and defeat is determined between heartbeats, the 3500dpi Razer Precision 3.5G infrared sensor translates your every movement into frags with pinpoint accuracy.
- 3500dpi Razer Precision™ 3.5G infrared sensor
- Ergonomic right-handed design
- 1000Hz Ultrapolling™ / 1ms response
- Five independently programmable Hyperesponse™ buttons
- On-The-Fly Sensitivity™ adjustment
- Always-On™ mode
- Ultra-large non-slip buttons
- 16-bit ultra-wide data path
- 60–120 inches per second and 15g of acceleration
- Zero-acoustic Ultraslick™ Teflon feet
- Gold-plated USB connector
- Seven-Foot, lightweight, braided fiber cable
- Approximate size: 128mm (length) x 70mm (width) x 42.5mm (height)
Only £49.98 inc VAT.
ORDER NOW
