Corsair Flash Voyager GO OTG Flash Drive 64GB (CMFVG-64GB-EU) @ £27.98 inc VAT
Imagine no more emailing photos to yourself, hunting for a USB cable, or running out of room on your USB On-The-Go compatible Android phone or tablet. Flash Voyager GO is the quick and easy way to move photos, music and videos between your mobile devices and your PCs and dramatically increase your devices’ storage. The ingenious design has both a USB and a Micro-USB connector, so you can copy photos and videos to your desktop or notebook PC for safekeeping, share music and media between your PCs and your Android device, or just leave it connected to the Micro-USB port for a huge boost to your device’s storage capacity.
Allows you to move and copy files between your Android device and your desktop/notebook PC without using a bulky cable.
Features:-
- Works with any USB On-The-Go compatible Android tablet or smartphone with a Micro-USB connector
- Dramatically boosts your mobile device¡¦s storage capacity
- USB 3.0 speed with USB 2.0 compatibility
- Plug and Play, with no driver or app necessary
- Includes extra caps and a lanyard for a personalized look and handy access
- Compatible with WindowsR 8, Windows 7, Windows VistaR, Windows XP, Mac OS, Linux
Only £27.98 inc VAT.
ORDER NOW
_____
Samsung 256GB SSD 850 PRO SATA 6Gbps 3D NAND Solid State Drive (MZ-7KE256BW) @ £134.99 inc VAT
The Samsung SSD 850 PRO delivers blazing-fast speeds with an exceptionally high endurance and provides the highest performance of SSDs with SATA III (6Gb / s) interface. The sequential read performance is achieved up to 550 megabytes per second (MB / s), the Write performance up to 520 MB / s The random read performance of up to 100,000 Input/Output- Operations per second (IOPS), the write speeds up to 90,000 IOPS.
The World's First 3D V-NAND SSD One giant leap ahead
NAND: Samsung V-NAND 32 Layer
Form Factor: 2.5" 7mm
Sequential Read: 550 MB/s
Sequential Write: 520MB/s
Random 4KB IOPS Read (QD=1): 10,000
Random 4KB IOPS Write (QD=1): 36,000
Random 4KB IOPS Read (QD=32): 100,000
Random 4KB IOPS Write (QD=32): 90,000
DevSlp Power: 2.0mW
Warranty: 10 Years / 150 TBW
Samsung's 3D V-NAND flash memory is fabricated using an innovative vertical design. Its vertical architecture stacks 32 cell layers on top of one another rather than trying to decrease the cells' length and width to fit today's ever-shrinking form factors. This architecture results in higher density and higher performance using a smaller footprint. Samsung's 3D V-NAND technology is a breakthrough in overcoming the density limits currently faced with conventional planar NAND architecture.
Boost performance with an industry-leading 3D V-NAND SSD
Powered by Samsung's own cutting-edge 3D V-NAND technology, the 850 PRO delivers up to two times the density and write speed when compared with traditional 20 nm planar NAND flash for the ultimate in read and write performance. By changing to a 32-layer cylindrical cell structure, more cells can be stacked vertically, resulting in a smaller footprint and higher density. As a result, you gain superior maximum read and write performance in both sequential and random aspects, especially the 128GB model that outperforms other similar models in the market by more than 100Mb/s in write speed.
Shift into high gear with the RAPID mode
Plus, you can kick up the read/write performance on every capacity when you need it with the RAPID mode. Just like shifting gears in a car, Magician software gives you the option to enhance performance by processing data on a system level using free PC memory (DRAM) as a cache. The 128 GB model, for example, is able to double its performance by using the V-NAND technology.
An SSD that won't quit before you do
With twice the endurance and reliability of a typical NAND flash SSD, the 850 PRO will keep working as long as you do. Samsung's V-NAND technology is built to handle an 80 GB daily workload, which equates to 150 Terabytes Written (TBW), enabling you to use the SSD for long periods of time. Plus, it comes with the industry's top-level ten-year limited warranty.
Work longer with high-efficiency innovation
The efficient, power management components in the 850 PRO enable you work longer and more productively. The 850 PRO boasts the lowest power consumption of any SSD when in full use so that power consumption is minimized while market-leading performance is maintained., And, in the device sleep mode, it consumes only 2 m watts of power, as determined in test results on an Ultrabook™ device. Plus, its LPDDR2 cache memory provides higher performance while consuming 30 percent less power when active and 93 percent less power when idle than typical DDR2 or DDR3 memory.
Safeguard precious data without sacrificing performance
When you take your laptop on the road, you not only need to protect your PCs hardware, but your personal data, too. But don't worry. The 850 PRO's Self-Encrypting Drive (SED) technology will help keep it safe, even if you lose your laptop. The drive includes an AES-256-bit hardware-based, full disk encryption engine that secures your data without performance degradation, which is often experienced with software-based encryption.
The 850 PRO's advanced security complies with the Trusted Computing Group™ (TCG) Opal v2.0 standards, protecting Postscript Image Data (PSID), and is compatible with the Microsoft? eDrive Institute of Electrical and Electronics Engineers (IEEE) 1667 protocol. Plus, you can erase or initialize data with the crypto erase service.
Protect your PC from overheating with Dynamic Thermal Guard Protection
To ensure it won't let you down, the 850 PRO includes Dynamic Thermal Guard protection, which keeps your PC performance safe from heat. After all, when you're totally immersed in your work or in a competitive video game, the last thing you want to have happen is for your computer to overheat. Dynamic Thermal Guard protection monitors and maintains the drive's optimal operating temperature with a throttle feature that automatically drops the SSD's temperature when necessary to protect your data and ensure the responsiveness you expect. So, your PC will stay cool, even if you overwork it - and you'll keep your cool, too.
Level up to the 850 PRO simply without any hassle
Samsung has made upgrading to the 850 PRO simple using its One-stop Install Navigator software. You can migrate all the data from your SSD or HDD to the 850 PRO quickly and easily. The Auto Install guide, included in the toolkit, guides you through the simple three-step installation process.
What's more, you can conveniently monitor, manage and maintain your new 850 PRO with the Samsung Magician software that's also available through the One-stop Install Navigator toolkit. The Magician features tools to help you maximize performance, including benchmarking, advanced OS optimization, disk health status tracking and over-provisioning (OP) settings.
Ensure each component works together seamlessly
Samsung is one of the few manufacturers that actually design all the SSD components in-house. And among those who do, Samsung has the most experience in the SSD market. Because Samsung has intimate knowledge of every component and its parts, it can fine-tune them at each stage of development to ensure they work perfectly together. The result – enhanced performance with a 32-layer 3D V-NAND flash memory, lower power consumption with an up to 1 GB LPDDR2 DRAM cache memory and improved energy-efficiency with the 3-core MEX controller.
Only £134.99 inc VAT.
ORDER NOW
Features:-
ORDER NOW
_____
DevSlp Power: 2.0mW
ORDER NOW
