**TODAY ONLY 08/01/2011 GTX 570 AND CORSAIR 4GB (2x2GB) 1600MHZ C9 KIT
11 Dec 2005
Cheshire
Today Only, we have 50 units of the OcUK GeForce GTX 570 1280MB GDDR5 Graphics Card featuring DX11 cinematic graphics and unprecedented graphical performance. Plough through even the most demanding game titles and smash your way to victory with the OcUK GeForce GTX 570 1280MB GDDR5 Graphics Card for only £275.99 inc VAT
We also have 200 units of Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit, built from the ground up and featuring Corsair trademark reliability, put your trust in Corsair memory. With a blistering quick 1600MHz frequency and C9 latency, this offer cannot be missed at only £35.99 inc VAT.
OcUK GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 732MHz
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 2 years
Only £275.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £35.99 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Only £35.99 inc VAT.
ORDER NOW
:eek: Great deals! I've actually already got a 570 and that EXACT same model ram on its way to me tho >_< what are the chances
i ordered the ram just, was exactly what i wanted and cheaper than everywhere else, only need a cpu now now so feel free to put the i5 760 on offer soon :)
thanks ocuk
How can i buy 2 of those ram?
Also i have ocz reaper low latency which i bought from OCUK and i was wondering if both memory will work ok together?
Just bought the ram too. I already own a set, but it's faulty. Though i've read they're not very compatible with AMD boards :confused:
It should be compatiable and don't you have lifetime warranty?
Yeah i have a warranty, but never bothered to rma it since i'd have no backup computer. So i guess i'll RMA it once the new set arrives...Can't remember where i read it, but a Corsair rep said there are issues with that ram and my mobo...
