Today Only 08/01/2014 - Antec HCP 1300W Platinum Continous Power Supply & Pioneer BDR-208EBK 15x Blu
22 Aug 2010
Today's deals!
Antec HCP 1300W Platinum Continous Power Supply @ £239.99 inc VAT
Antec's High Current Pro Platinum series is the pinnacle of power supplies. High Current Pro Platinum is fully modular with a revolutionary 20+8-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS® PLATINUM & ErP Lot 6: 2013 certified, operating up to 94% efficient, you can reduce your electricity bill by up to 25% when compared to many other power supplies. HCP Platinum's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. All cables are darkened to become Stealth Wires and are thus nearly invisible in your chassis. 4 High Current Rails and a 100% +12V output ratio maximize HCP-1300 Platinum's capabilities to power the latest CPU's & GPU's. HCP Platinum's PhaseWave™ Design is a server-class "full-bridge" LLC design with a synchronous rectification based on a DC-DC topology. All Japanese capacitors achieve unprecedented tight voltage regulation & low ripple & noise to maximize your system's performance. Antec's intelligent Thermal Manager fan control spins the high-quality 13.5cm DBB fan optimally to cool your PSU quietly. CircuitShield™ makes the HCP-1300 Platinum safe and reliable in any environment with its nine industrial-grade protections. Backed by a 7 year warranty and lifetime global 24/7 support, the HCP-1300 Platinum embodies everything a power supply can accomplish today.
Specification:-
- 1300W Continuous Power - Guaranteed 1300W of Continuous Power from Antec
- 80 PLUS® PLATINUM certified - Up to 94% efficient, to reduce your electricity bill
- Save Energy and Money - Reduce your electricity bill by up to 25%
- AQ7 - Antec Quality 7 year warranty and lifetime global 24/7 support
- 16-pin Socket - Industry-leading 16-pin sockets double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future connector changes
- 28(20+8)-pin MBU socket - World's first socket for possible future MBU connectors
- 135 mm DBB Silence - Whisper-quiet high-quality double ball bearing fan with long lifetime
- Thermal Manager - An advanced low voltage fan control for optimal heat & noise management
- High Current Rails - 4 High Current +12V rails with high load capabilities ensure maximum CPU & GPU compatibility
- 100% +12V - Output for maximum CPU & GPU support
- Multi PCI-E - 10 PCI-E connectors for multiple GPU support
- OC Link™ - Allows 2 HCP Platinums to work in tandem to power the most demanding systems
- CircuitShield™ - Full suite of industrial grade protections: Over Current Protection (OCP),
- Over Voltage Protection (OVP), Under Voltage Protection (UVP), Short Circuit Protection (SCP), Over Power Protection (OPP), Over Temperature Protection (OTP), Surge & Inrush Protection (SIP), No Load Operation (NLO) & Brown-Out Protection (BOP)
- All Japanese Heavy-Duty Caps - All high-performance Japanese capacitors ensure tightest DC stability and regulation
- PhaseWave™ Design - A server-class full-bridge LLC design with a synchronous rectification based on a DC-DC topology
- Stealth Wires - All wires darkened for minimal visibility in chassis
- Connectors: 1 x 24pin, 1 x 8pin(4+4pin)ATX12V/EPS12V, 1 x 8pin EPS12V, 10 x 8pin(6+2pin) PCI-Express, 6x Molex, 9 x SATA, 1 x Floppy, 1 x OC Link
- Warranty 7yr
Only £239.99 inc VAT.
ORDER NOW
Pioneer BDR-208EBK 15x BluRay RW / 16x DVD±RW 128GB - Retail @ £64.00 inc VAT
This Internal BD/DVD/CD Writer will write up to 12x on BD-R (25 Gbytes) and BD-R DL (128 Gbytes) media. It allows users to author high-definition Blu-ray Disc content while also delivering the ability for high-capacity data storage.
Key Features
- Max Write Speed: 16x DVD, 15x BD-R, 40x CD-R
- Max Read Speed: 16x DVD, 15x BD, 40x CD-R
- 4MB buffer memory
- Serial ATA (SATA) interface
Only £64.00 inc VAT.
ORDER NOW
