**Today Only 08/03/2012** Hazro HZ27D 10-Bit 27" LED Widescreen & Kingston HyperX RED Limited Editio
22 Aug 2010
Today only deals :)
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Monitor - Black @ £479.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WA features dual scalers and a glossy 10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs. With HDMI, DVI and Component (Y/Pb/Pr) inputs, interacting with high definition video and media input has never been easier.
Features:-
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x DisplayPort
- 2 x HDMI
- 1 x Dual Link DVI-D [HDCP Supported]
- 1 x RGB VGA
- 1 x Component Y/Pb/Pr
- 1 x L/R RCA Audio
- 2.5mm Audio in & out
- SPDIF Optical Out
- 1 x USB [service port]
- Kensignton Security Port
- 10bits [1.07Billion colors with A-FRC]
- 27” Diagonal 68.47cm (WQHD), 59.67x35.57cm visible area
- 1000:1(Typ.) / 1,000,000:1(Dynamic)
- Dual Link DVI-D Cable, HDMI Cable, VGA Cable, 2.5mm Audio Cable, 24V External
- PIP Supported; 1:1 mapping/ Aspect Ratio
- Tilt: VESA 100x100 (M4 thread]
- Speakers: Yes, 5W Per Channel; max 10W
- Only available to customers in the United Kingdom
- 3yr RTB Warranty (UK customer only)
Only £479.99 inc VAT.
ORDER NOW
Kingston HyperX RED Limited Edition 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3B1RK2/8GX) @ £35.99 inc VAT
Kingston’s HyperX® Red Limited Edition is specially designed to enhance high-performance systems. It features a sleek and aggressive look to complement any compatible motherboard and desktop computer. HyperX Red Limited Edition is available in 4GB single modules or 8GB kits. It comes in speeds of 1333MHz and 1600MHz and voltages of 1.5V and 1.65V to meet the demands of gamers, enthusiasts, system builders and consumers looking for high-performance upgrades.
HyperX Red memory modules have been maximised for optimal heat dissipation. In addition, the 1600 MHz 8GB kits are fully XMP-ready to enable easy overclocking for optimum performance. All HyperX memory products come with a lifetime warranty, free technical support and legendary Kingston® reliability
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Warranty: Lifetime
Only £35.99 inc VAT.
ORDER NOW
whats the difference between 10-bit monitor and the standard one?
Ive been seeing a lot of 10-bits lately around the net specially on videos
I guess it's that bit from the description:
"10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs."
Have the Hazro myself, a cracking monitor! :D
Dave, the D model on offer here has more inputs and is 10bit vs. 8bit for the lower priced ones. This model also has an actual screen interface where you can adjust colours etc where the lower priced models are pretty much plug and play.
However, you do need quite a beefy GPU to power games at this res :(.
