Raijintek Aeneas mATX Cube Case - White @ £49.99 inc VAT
AENEAS, Raijintek’s special type chassis – Cube Micro ATX, is developed with elegant design, super intake/outtake airflow, and spot catch LED bar. Not only AENEAS brought to you fashion and elegant style, but AENEAS also brings you a sturdy chassis body (0.8mm SGCC) and with surprising function and features.
With awesome fan installation function to provide cooling performing, AENEAS is bale to install Max. 8 fans, 200mm fan optional at front, 2 * 140mm fans pre-installed at rear, 2*120mm fans pre-installed at front, and additional to install 240mm radiator at front or top. Superior features includes Removable M/B plate for easy installation of coolers, Switch off button of LED lighting, Compatible wtih 180mm height CPU cooler, VGA card length to 310mm and Regular ATX PSU compatibility. What a awesome chassis enthusiasm is looking for, it must be AENEAS.
- Elegant LED light bar design (on/off switch)
- User Friendly design – removable M/B frame and tool-free screws
- Classic design with efficient and mass airflow
- Complete black coated interior
- Dust-control filters for all mesh area
- Sturdy and reliable chassis body Chassis body: 0.8mm SGCC
- Accommodate an internal 240 mm radiator at front ; an 280mm radiator at top
- Powerful fan systems pre-installed: two 140mm at rear; two 120mm at front.
- Supports to up to eight fan installation; 200mm fan option at front
- Supports to install four 3.5”HDD (or four 2.5” HDD) and five 2.5” HDD (optional cage)
- Fully supports Tool-free for ODDs & HDDs
- Two high speed USB3.0 and two USB2.0
- Supports VGA card up to 310mm
- Support CPU cooler height up to 180mm
Specfication:-
- Internal color Matt Black
- Dimension chassis body (D/W/H) 352*288*380mm
- Dimension chassis body (D/W/H) 380*288*430mm
- Body Weight (N.W.) Kg
- Material SGCC 0.8mm
- M/B Type MICRO-ATX?ITX
- Graphic Card Support yes
- Power Supply PS-2
- Power Supply Integration Internal Bottom PSU (vertical)
- 5.25" Drive Bays 1
- 3.5" Device 1 exposed +4 hidden
- 2.5" Device (option/removable) 5
- I/O Panel USB3.0 *2 + USB2.0*2
- Hot Swappable n/a
- PCI Slot 5
- PCI Slot Tool-free Yes
- ODD & HDD Tool-free Yes
- CPU Cooler Height 180mm max.
- Graphic Card Length 310mm
- Side Panel Style Flat / Vent
- Cable Management Regular
- Water Pipe holes 2
- Front Cooling Fan 120mm*4 (2pcs pre-installed) ; 200mm fan (option) or
- 240mm radiator (option)
- Rear Cooling Fan 140mm*2pcs (pre-installed)
- Left Side Cooling Fan Option
- Right Side Cooling Fan option
- Top Cooling Fan 140MM*2 (option)
- or 280mm radiator (option)
Only £49.99 inc VAT.
ORDER NOW
______
Corsair Flash Voyager GS 64GB USB 3.0 Flash Drive (CMFVYGS3B-64GB) @ £42.98 inc VAT
Flash Voyager GS is a large-capacity, high performance USB 3.0 flash drive in a sleek, stylish enclosure. It takes full advantage of the high-speed USB 3.0 interface, and provides full USB 2.0 backward compatibility for older systems. With a read speed of 295MB/s and write speeds of 170MB/s, it makes quick work of the largest files.
The zinc alloy housing is accented with inlaid aluminum for a premium look. It can be attached to a key ring, so you’ll never forget your USB drive at home again.
It’s compatible with Windows, Mac OS X and Linux, with no driver installation necessary. Just plug it in and go!
Features:
High-speed USB 3.0 interface - Move files significantly faster on the latest systems.
Performance tuned - Read speed up to 295MB/s and write speed up to 170MB/s.
Premium design - A zinc alloy casing with aluminum accents protects your data in style.
USB 3.0 and USB 2.0 compatible - Take advantage of faster speed on the newest systems and enjoy full support on older systems
Universal compatibility with Windows, OS X and Linux - Just attach it and go. No driver installation is necessary.
5 years warranty - Peace of mind. A statement of Corsair product quality and reliability.
Technical Specs
Unformatted Capacity : 64GB
Max Sequential Read (CDM) : Up to 295MB/s
Interface Type: USB 3.0, USB 2.0 compatible
Max Sequential Write (CDM)2 : Up to 170MB/s
Only £42.98 inc VAT.
ORDER NOW
Specfication:-
- Power Supply PS-2
- Hot Swappable n/a
- PCI Slot 5
ORDER NOW
______
Features:
Technical Specs
ORDER NOW
