**TODAY ONLY! 08/05/2014** Gainward GeForce GTX 770 Phantom 4GB & MSI GS70 2PE-014UK Stealth Pro 17.
OcUK Staff
4 Feb 2013
Gainward GeForce GTX 770 Phantom 4096MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
Gainward GTX 680 Phantom, continue the elegant design of the first generation. The new Phantom III comes with brand new fins design (patent pending) that introduces 1) better thermal performance 2) lower acoustic level 3) more solid structure than previous generation. With this new outstanding innovated thermal design and optimized product design Gainward GTX 770 Phantom delivers an extreme gaming performance for enthusiast gamers.
Gainward Grand-Prix Heat-Pipes Hybrid Cooler, was designed in 8mm copper-water heat-pipes on a copper base conducting heats away from GPU at highest efficiency, then dissipating onto aluminum heatsinks, which are forced ventilated with Great 8 cm silent PWM fans (GR8) which are also removable.
Great 8 cm silent PWM Fan (GR8) achieves highest cooling performance at much lower temperatures under power saving mode.
Specification:-
- Core Clock: 1046MHz (GK104)
- Core Boost Clock: 1085MHz
- Memory: 4096MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2300MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Only £275.99 inc VAT.
ORDER NOW
_____
MSI GS70 2PE-014UK Stealth Pro 17.3" True HD LED GTX 870M 3GB 4700HQ, 16GB DDR3, 128GB SSD, 1TB HDD - Windows 8.1 @ £1,379.99 inc VAT
The NVIDIA GeForce GTX 870M leverages NVIDIA's revolutionary new architecture to deliver extreme performance than the previous generation. Compare to GeForce GTX 770M, users could get over 35% faster and more performance at same level new graphics card with lower temperature and watts. Turn on lightning-fast antialiasing in a huge variety of games automatically. Get maximum gaming images and best compatibility with NVIDIA graphics. Feel the difference reality with NVIDIA PhysX® technology , bringing games to life with dynamic, interactive environments.
The latest 4th generation quad core processor platform, representing superior performance over previous generations. The CPU performance has increased by 3%~7%, while the overall platform is 15% more powerful. Additionally, the GPU performance of 2d and 3D visuals, is even more noteworthy, with an average increase of over 30%. There have also been significant advances in user experience and battery life. Moreover, it employs a more advanced encryption program to help businesses enhance information security and to protect your BIOS/FW from attacks by malware.
SteelSeries Engine is the Apps to combine all frequent functions for gamers in order to easily customize every individual key and functions to personalize every gamer’s play style, including KLM, multiple devices management (for example, headset, mouse, and keyboard), keypress macros, and text macros.
There are 4 layers for gamers to set 4 usage scenario or game. Not only that, while playing the game, gamers can easily and quickly switch layer*, such as a chat screen with friends. Communication with friends is not interrupted!! There are virtually unlimited keypress macro creation capabilities. Anything you can do on a mouse or a keyboard can be programmed along with specific event timing. You can even program mouse events into keyboard macros. Your macros will be running at a high priority in your computers Operating System, yet it does NOT interfere with your real time actions during gameplay. Besides keypress macro, SteelSeries Engine also can create the text macro for gamers’ talk. By this way, gamers can have simultaneously multi-party conversation and do not waste time in doing repetitive typing. Depending on your mood and desires, you can choose from more than 1,000 color combinations and five different scenario modes for the keyboard, enabling you to be the coolest gamer at any LAN party! Profiles are sets of macros, button assignments, and device configurations that are frequently used together. An unlimited number of profiles, with customizable names, can be stored in the SteelSeries Engine. It provides predefined profiles for common games which can be used directly or as templates for your custom macros. Whether you're playing an FPS or editing in Photoshop, being better and more efficient is something we want to help you achieve. Use the Statistics module to record your keyboard or mouse actions. Then review the peripheral heat map, which shows with both color and numbers the frequency of your key or button presses. You can then use this information to fine tune your macros as well as your key and mouse button assignments to optimize your tools to play (and work). SteelSeries Engine will automatically recognize what game you are playing and open your saved profile(s) for that game. You can create your own profiles for other applications and then have SteelSeries Engine open the corresponding profile when you start up your application.
Super RAID 2 design gives the storage performance up to 1500MB/s storage performance, the reading, writing and saving speeds is 15x faster than a single 750GB 7200rpm HDD. And one more HDD can be installed in the same laptop without the need to expand the size to put recovery system, to backup and put more data.
To satisfy consumers desire to experience high quality sound effects, MSI partnered with top audio brand Dynaudio, which has a devoted aspiration for “Authentic Fidelity” to meet this demanding standard. It equips the MSI GAMING-Series gaming notebook with top-notch audio features, creating a realistic sound and immersive effects. Besides, GS70 Stealth produces rich and immersive 2.1-channel surround sound. Any high quality stereo source is transformed into true-to-life, multi-channel sound. Besides, a woofer for extra-impactful bass let users experience dynamic and rich bass sounds. No need to purchase extra speakers, wires or speaker stands to appreciate room-filling sound.
Stay stealthy and cool with the quiet yet efficient dual fan thermal cooling solution for optimal airflow. The automated cooler boost feature intelligently increases airflow during extreme gaming sessions to keep you cool in the heat of battle. Matrix display features MSI innovative design with 3 external screen display capabilities, allowing you to output to 3 displays simultaneously using HDMI 1.4, and mini Display-Port 1.2 port. Users can work with multi-task at same time. Handle the big screen with support of up to 3840 x 2160 resolutions to watch your movies or play your games in true HD when connected to an HDTV.
The MSI Audio Boost design enhances the output sound detail and sound stage by 30% more. The gold flash audio jack provides stable sound transmission (reduced obstruction) and works in conjunction with the optimized headsets AMP (Audio Power Amplifier) design, characterized by low noise and low distortion, to greatly enhance headphone performance and faithfully reproduce each acoustic detail.
The benefit of the Killer Gaming LAN is the "Advanced Game Detect™" technology, which recognizes online game data packs and processes them first, accelerating them in the process. The best weapon against stuttering characters, freeze-ups, and lagging, it vastly improves all the online experience. Whether FPS or MMO gaming, you’ll have that advantage to response faster to get victorious. Hear your enemies perfectly, even on an ear-drum shattering battlefield. Thanks to Sound Blaster Cinema, you're getting amazing surround sound with just stereo headphones. Your most important gaming sound effects are reproduced crystal clear allowing you to focus on your game even during extremely long gaming sessions.
Features:-
- Windows 8.1
- The latest 4th generation Intel® Core™ i7 Processor
- Thinnest & lightest 17" gaming notebook
- Enthusiast level NVIDIA® GeForce GTX 870M graphic discrete graphics card provides great performance and ultra image quality
- SteelSeries Engine to customize every key and devices for personalizing your play style
- XSplit Gamecaster for easily recording gaming moments, broadcasting and sharing live gameplay sessions to YouTube, Twitch, UStream and more
- Exclusive Super RAID 2 with 3 SSD RAID0 gives over 1500MB/s reading speed! (option)
- Dual fan thermal cooling
- Keyboard by SteelSeries with full color LED back light and solid feedback design lower latency of online gaming and streaming
- Killer™ E2200 Game Networking for smarter, faster, networking for all online entertainment
- Sound by Dynaudio and 2.1 channel 4 speakers
- Matrix display with max 3 displays to expend the vision for extreme gaming experience or multi tasks
Specification:
- Screen Size: 17.3"
- Screen Type: LCD
- Backlight: LED
- Screen Resolution: 1920x1080
- Aspect Ratio: 16:9
- Screen Features: Full HD
- Processor Type: Intel Core i7 4700HQ
- Processor Cores: 4 (8 Threads)
- Processor Clock Speed: 2.40GHz (3.40GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 128GB SSD x1
- Hard Drive Interface: Serial ATA-600
- Hard Drive Speed: 7200RPM
- Memory Supplied: 2x 8GB
- Memory Size: 16GB
- Memory Type: DDR3
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 32GB
- Operating System: Windows 8
- Graphics Chipset: NVIDIA GeForce GTX 870M
- Graphics Memory: 3GB GDDR5
- Chipset: Intel HM87 Express
- Audio: Sound by Dynaudio
- Speaker(s): 2 x Speakers
- Subwoofer: 1 subwoofer
- Microphone: Built-in
- LAN Card: Killer E2200 LAN
- LAN Speed: 10/100/1000
- Wireless NIC: Killer N1202 Combo (2*2, a/b/g/n)
- Bluetooth: v4.0
- USB 3.0 Port(s): 4
- HDMI Port(s): 1
- Mini Display Port(s): 2
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- Line In Jack(s): 1
- Line Out Jack(s): 1
- LAN Port(s): 1
- Battery Life: 4hrs
- Card Reader: SDXC/HC
- Web Camera: HD type ( 30fps@720p)
- Only 22mm thick
- Product Weight (g): 2.6Kg (w/Battery)
- Warranty: 2 Years
Only £1,379.99 inc VAT.
ORDER NOW
For deal of the day, its not much of a saving on the laptop, less than 1.5%, I personally think that to be deal of the day it should be atleast 10% off things.
It's normally around that area anyway.
