**TODAY ONLY! 08/05/2015** Asus VX24AH 24" Widescreen Zero Frame Monitor & LG 34UC87-P 34" Superwide
OcUK Staff
4 Feb 2013
Asus VX24AH 24" Widescreen Professional/Gaming LED Zero Frame Monitor - Black @ £239.99 inc VAT
Envision bigger with 2560 x 1440 WQHD, packing four times the pixel density of 720p! New premium 16:9 wide-format VX24AH LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive SplendidPlus Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true “what you imagine is what you create” power. Dual HDMI support WQHD natively, accentuated by room-dominating audio via twin 2W speakers.
The VX24AH WQHD monitor high quality 2560 x 1440 visuals – equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays.
The ASUS VX24AH provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy 77% more desktop space than a full HD screen to spread out your windows and palettes. It is also about 25% sharper than a generic 24” full HD display, delivering ultra-smooth visuals thanks to 5ms (GTG) response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color.
The VX24AH features a host of connectivity options that include HDMI for native WQHD, plus D-sub for full HD 1080p content transmission. The HDMI port also supports MHL which allows you to use the MHL with HDMI connection to view content from your mobile device on the VX24AH while simultaneously charging the mobile device. Twin built-in 2W speakers provide quality audio for a completely immersive home theater experience.
ASUS includes its exclusive QuickFit Virtual Scale feature with the VX24AH, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
Features:
- Impeccable lifelike visuals with 24” 16:9 2560 x 1440 with 100% sRGB & 178° wide-viewing angle
- Extensive connectivity with native WQHD content support with dual HDMI and VGA
- ASUS-exclusive QuickFit Virtual Scale and SplendidPlus Video Intelligence Technology for true ‘what you see is what you get’
- ASUS Eye care technology with flicker free & low blue light for less eye fatigue
Specification:-
- Panel Size: Wide Screen 24"
- Panel type: IPS
- True Resolution: 2560x1440
- Pixel Pitch: 0.2745mm
- Brightness(Max): 300 cd/m
- ASUS Smart Contrast Ratio (ASCR): 100000000:1
- Viewing Angle (CR?10): 178°(H)/178°(V)
- Response Time: 5ms (Gray to Gray)
- Display Colors: 16.7M
- Signal Input: 2x HDMI , D-Sub
- AV Audio Input: HDMI
- Earphone jack: 3.5mm Mini-Jack (for HDMI Only)
- Chassis Colors: Black
- Slim Design: Yes
- Speakers: 2x 2W Stereo
- Warranty: 3yr (On-Site with Asus - 01442 265 548)
Only £239.99 inc VAT.
ORDER NOW
______
LG 34UC87-P 34" WideScreen Super-Wide Curved LED Monitor @ £599.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
IPS’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved IPS provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 99% colourspace and IPS’s accurate colour expression.
34UC87 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC87 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC87 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Speakers: 2x 7W
- Height adjust stand
- VESA: 100x100mm
- Set with stand: 830.5 x 224.5 x 472.9
- Set without stand: 830.5 x 106.4 x 370.3
- Weight: 8.2kg
- Warranty: 2yr (On-Site with LG - 0344 847 5454)
Only £599.99 inc VAT.
ORDER NOW
If only the Asus VX24AH had VESA mounts! Would be so tempting to swap my triple 1080p setup for something with a bit more res.
Very nice price on the lg just a shame that the majority of them suffer horrendous bleed and LG's service is absolute crap.....
I'd prefer 27" for 1440p and dang dat LG is sexy. I want a new GPU and monitor
Bleed seems to be a common problem though and you could say the same about customer service LOL. These monitor manufacturers need to sort it out :(
Yup unfortunately very true, QC and CS for monitors has gone down the drain lately :(
So many monitor brands I won't touch now!
