Two fantastic graphics card deals on offer today, in which you could save up to £101.96!!!
Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card @ £347.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The PCB also seems to be a non-reference design.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 3072MB GDDR5
- Memory Clock: 4020MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1566MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 2 Years
Only £347.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 570 Golden Sample 1280MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 750MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3900MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1500MHz
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI, 1x Displayport
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Only £179.99 inc VAT.
ORDER NOW
Features:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
Features:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
ORDER NOW
