BitFenix Spectre PRO 120mm Fan - All White @ £5.99 inc VAT
Following the success of our Spectre™ Fan Series, Spectre Pro ups the ante with an all-new design and enhanced performance. The high pressure and CFM design produces wicked cooling and is also perfect for watercooling setups. Its dual frame construction not only looks great, but also helps to dampen vibrations that cause unnecessary noise. Reinforced fan blades prevent warping at high RPM levels, while focused airflow ensures cool air can reach all of your installed components. With FDB technology for low noise and long life, and availability in both LED and non-LED varieties, Spectre Pro is the new gold standard in performance case fans.
Harness the fury with the Spectre Pro Fan Series.
Harness the fury with the Spectre Pro LED Fan Series.
- Dimensions (mm): 120x120x25mm
- Current (A): 0.11A ±10%
- Speed (RPM): 1200 RPM ±10%
- Air Flow (CFM): 56.22 CFM ±10%
- Air Pressure (mmH2O): 1.24 mmH2O
- Noise (dB-A): 18.9 dB(A)
- Colour: White
Only £5.99 inc VAT.
ORDER NOW
_____
FreeCom 500GB USB 3.0 2.5" Portable Hard Drive Black (35607) @ £29.99 inc VAT
Compact storage on the go !
Whether you are a professional or home user, these days it is essential to be able to carry your valuable data anywhere with you. Ultra compact, easy-to-use and secure, this USB 3.0 powered portable hard drive makes transporting and sharing data easier than ever. Simply plug it into any computer’s USB port and take your spreadsheets, documents, movies, photo’s or music anywhere you go. The perfect travel companion !
Need to expand your notebook, PC or Mac with a high capacity drive? Don’t want annoying noises while working? No problem, The Freecom Mobile Drive Classic 3.0 has no cooling fan, which ensures quiet operation at all times !
Need a hard drive but want to be trendy as well? The Freecom Mobile Drive Classic 3.0 has a stylish black design. IIt will look perfect next to your netbook or notebook !
USB Recording – what is it?
The last few years more and more TV’s are equipped with one or more USB port(s). We have already grown accustomed to playing back photos and movies from a USB hard drive or USB stick on the TV. Now an additional USB feature has been added to TV sets – USB Recording. If you have recently bought a new TV there is good chance that it will support USB Recording, in particular when you have bought a mid range or high end TV.
USB Recording enables you to record programmes to an external storage device directly connected to your TV via USB. Your external HDD basically acts as a videorecorder. You can also use it to pause live TV.
Only £29.99 inc VAT.
ORDER NOW
- Colour: White
Only £5.99 inc VAT.
ORDER NOW
_____
ORDER NOW
