**Today Only 09/07/2013** BitFenix Colossus Blue & Red LED Big Tower Case & Hitachi Deskstar 7K4000
22 Aug 2010
Today's Deals!
BitFenix Colossus Blue & Red LED Big Tower Case - Black @ £119.99 inc VAT
Introducing BitFenix Colossus – the PC chassis for the uncompromising enthusiast. Offering unmatched expandability, security, and cooling all wrapped up in a modern and elegant body, Colossus represents months of intensive research, product development, and meticulous design. The result is a chassis like no other; a chassis that serves as an ideal enclosure for the most colossal gaming rigs.
Ready for the Future
The next generation of USB connectivity is here. Equipped with two USB 3.0 ports, Colossus allows you to connect an ever-growing number of USB 3.0 devices and experience data transfer speeds up to ten times that of USB 2.0. With USB 3.0 already built-in, Colossus can last you several upgrades, further future-proofing your system.
At Your Command
Designed to be the center of your digital domain, Colossus puts you in command with a PWM fan controller and multimode light controls. Tune your fans down for silence or up for extra cooling. Select your desired lighting color or turn them off completely. With Colossus, control is always at your fingertips.
Advanced LED Lighting System
Perhaps the most striking feature of Colossus at first glance is the advanced LED lighting system. Not only is the light evenly distributed for a truly inspired look, but the LED color is also dual-mode, which means that users can switch between red and blue lighting with the touch of a button.
Unmatched Security with BitFenix S3
Colossus introduces a BitFenix exclusive – S3. S3 is a storage compartment and security system in one. Place your iPhone, hard disk, or other valuables in S3 and lock them away for safe keeping. S3 will even lock down peripherals like USB mice and keyboards plugged into it, and secure everything under lock and key. Simple, safe and secure – that’s BitFenix S3.
Complete Cable Management
Messy cables not only look bad, but they can also restrict airflow in a chassis. That’s why Colossus is designed to manage cables both inside and out. Keep cables from cluttering the inside of the chassis with Colossus' strategically-placed cable holes. Prevent cables from getting caught in opening optical drives with the unique cable-holding front bezel.
Epic Expandability
Colossus gives you the space to build your own supercomputer. Capable of accommodating eight PCI express devices and seven 2.5" SSDs or seven 3.5" hard disk drives, Colossus is ready for multiple upgrades – perfect for a rig of epic proportions.
Massive Cooling
When the action heats up, your system needs to keep its cool. Colossus can be outfitted with up to two 230mm fans, three 140mm fans, or three 120mm fans, meaning huge cooling potential for all system components.
Easy Installation
Big doesn't have to mean unwieldy. Featuring a motherboard CPU cooler cutout on the motherboard tray, specially-designed motherboard standoffs, and an almost completely tool-free design, getting your system up and running with Colossus is a joy. Large yet welcoming, if Colossus reminds you of a friendly giant, we wouldn’t blame you.
- Materials SECC, ABS
- Color (Int/Ext): Black
- Dimensions (WxHxD): 245 x 558 x 582 mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, E-ATX
- 5.25" Drive Bays: x 5 (1 x external 3.5"; tool-free)
- 3.5" Drive Bays: x 7
- 2.5" Drive Bays: x 7 (using standard 3.5" drive bays)
- Cooling Front: 1 x 230mm included
- Cooling Rear: 1 x 140/120mm (not included)
- Cooling Side Panel: n/a
- Cooling Top: 1 x 230mm included (or 1 x 140/120mm not included)
- Cooling Bottom: 1 x 140/120mm (not included)
- PCI Slots: 8 (tool-free)
- I/O: 2 x USB3.0, 2 x USB2.0, eSATA, Audio
- Power Supply: PS2 ATX (bottom, multi direction)
Only £119.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K4000 4TB SATA 6Gb/s 64MB Cache 7200RPM - OEM (0S03356) HDD @ £137.99 inc VAT
The Deskstar hard drive delivers colossal storage capacity and 7200 RPM performance in a standard 3.5-inch form factor. The Deskstar has a robust mechanical design that exceeds the industry standard for quality and reliability. Through a patented ramp load/unload design, the risk of shock damage is minimized by eliminating direct contact between the heads and disks, reducing wear and heat while improving overall drive reliability and power efficiency.
- Capacity: 4TB
- 64MB Buffer Size
- Spin Speed: 7200 RPM
- SATA III (6Gbps)
- 3.5" Standard Size
Only £137.99 inc VAT.
ORDER NOW
Never been a big fan of the BitFenix Colossus due to its looks, but if you like the looks its a good big old case shouldn't have any problems with cooling options
