**TODAY ONLY! 09/10/2014** Cooler Master Cosmos II Ultra Tower Case & TP-Link AV200 Mini Powerline S
OcUK Staff
4 Feb 2013
Cooler Master Cosmos II Ultra Tower Case - Black @ £249.95 inc VAT
The flagship case of Cooler Master - COSMOS II, is defined as the “Ultimate platform for extreme performance”. Its streamlined design with aluminum and mesh makes this product incomparably stylish and luxurious. It supports up to 10 fans, 13 HDDs, and 4 Way SLI/CF; also features an Advanced Control Panel for fan speed adjustment with LED indicators. The rich I/O includes 2 high speed USB 3.0 ports for quicker data transfer. The combination of its elegant looks, numerous expansion options, and functionality make the COSMOS II a definite choice for a user’s “Dream Case”.
- Stylish and streamlined race-car inspired design
- Brushed aluminum and steel for strength and elegance
- Airflow optimized design
- Supports up to 10 fans and 13 HDDs (2 from X-dock)
- Supports 4 Way SLI/CF
- Supports XL-ATX / SSI CEB / SSI EEB boards
- Advanced Control Panel:
- 4 channel fan speed control
- Materials Appearance: Aluminum, Mesh, Plastic/ Case body: Steel
- Dimensions: 344(W) x 704(H) x 664(D)mm / 13.5 x 27.7 x 26.1 inch
- Weight: 21.5kg
- M/B Type: Micro-ATX, ATX, E-ATX, XL-ATX, SSI CEB, SSI EEB
- 5.25" Drive Bay: 3
- 3.5" Drive Bay: 13 (2 from X-dock, Middle cage for 5 HDDs, Bottom cage for 6 HDDs:
- 2.5”/3.5" Drive Bay 11 (converted from 3.5" bay)
- I/O Panel: USB 3.0 x 2, USB 2.0 x 4, E-SATA x 1, Audio In and Out
- Expansion Slots: 10+1
- Front Cooling: 200mm LED fan x 1 (converted from 120/140mm x 1)
- Top Cooling: 120mm black fan x 1 (converted from 200mm fan x 1/ 140mm fan x 2 / 120mm fan x 3)
- Rear Cooling: 140mm fan x 1
- Side Cooling: 120mm fan x 2 (optional)
- HDD: 120mm fan x 3 (2 for bottom HDD / 1 for Mid. HDDs)
- Maximum Compatibility: CPU cooler height: 190mm / GPU card length: 385mm
Only £249.95 inc VAT.
ORDER NOW
_____
TP-Link AV200 Mini Powerline Starter Kit (TL-PA210KIT) @ £14.99 inc VAT
Featrures:
HomePlug AV standard compliant, high-speed data transfer rate of up to 200Mbps, enough for HD video streaming
Super Small Design with a new exterior, blends in completely in front of any power outlet
No new wires, uses existing electrical wires
Up to 300 meter range over the household power circuit for better performance through walls or across floors
Easy Plug and Play operation, No configuration required
Patented Power-Saving Mode automatically reduces power consumption by up to 65%*
Establish a 128-bit AES encryption to secure powerline communications simply by pressing the Pair button on the adapter
Supports IGMP managed IP transmission, optimizes IPTV streaming
A wide range of plug type including EU, UK, AU and US ensures that it can be used nearly all over the world
What This Product Does
TP-LINK's TL-PA210 powerline adapter takes advantage of your home's existing electrical wires to transfer data while simultaneously transferring traditional power. That means, with no additional wiring required, users can simply plug the TL-PA210 into existing power sockets and instantly establish a networking infrastructure. With high-speed data transfer rates of up to 200Mbps, users can enjoy HD video streaming, online gaming, VoIP or any other bandwidth intensive tasks for work or play.
Super Small Design
With its new ultra-compact housing design, TP-LINK's TL-PA210 is much smaller than most other 200Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it nearly blends completely in front of any power outlet.
Up to 200Mbps, 300 Meters
With advanced HomePlug AV technology, TL-PA210 provides users with stable, high-speed data transfer rates of up to 200Mbps on a line length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-PA210 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
Reduces Power Consumption Up to 65%
The TL-PA210, a new-generation Powerline Adapter, with its practical design and sophisticated Power-Saving Mode consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce its energy consumption by up to 65%*.
*Actual data will vary because of the network conditions and environmental factors
Pair Button for Easy Network Security
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection. It's that simple!
Plug the adapter into the power outlet
Connect the device via the network cable to the adapter
Press the encryption buttons—and you're done!
Only £14.99 inc VAT.
ORDER NOW
If those powerlines were pass-through, I've have them in an instant :)
Good price regardless.
I already have an excellent TP-Link powerline from OcUK (500Mbps version) and what is needed here is more stock of 8-port switches - ideally unmanaged 1000Mbps ;) for multiple connections via bluray/streaming/sky, etc for living room.
Hasn't been much in for a while (unless I missed the boat somewhere) for such uses and I already max out a 4-port. Been needing one for a while cos WiFi is hopeless for streaming with our thick walls. Don't have any in mind but has to fit on top of Sky+HD box - come on OcUK please bring more stock in cos I know you can do it! :)
Well Anderp, you've saved my bacon (again) I needed a pair of the powerline adaptors as Grimley Senior (yes there is one :p) has nagged me for weeks to buy some.
