Two great monitor deals today. Save up to £56!
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £119.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
- Warranty: 2 Years On-Site
Only £119.99 inc VAT.
ORDER NOW
Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey @ £515.99 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Dell U2711 Monitor delivers stunning detail, depth and responsiveness. PremierColour technology allows the Dell U2711 Monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. Factory-tuned Adobe RGB and sRGB modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.Customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 80000:1
- Brightness: 350cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 2x DVI-D, 1x HDMI, 1x DisplayPort, 1x Composite & 1x Component
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant
- Dimensions: 646.71mm x 427.83mm x 199.95mm
- Weight: 7.72kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Only £515.99 inc VAT.
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 4.4kg
ORDER NOW
- Height Adjustable
- 4-Port USB Hub
- VESA Compliant
- Weight: 7.72kg
ORDER NOW
