**TODAY ONLY! 10/02/2014** OcUK Tech Labs Noise Dampening O-Rings & Ducky ABS Pink Keycap Set
OcUK Staff
4 Feb 2013
OcUK Tech Labs Noise Dampening O-Rings for Cherry MX Keyboards - 125 pieces @ £6.95 inc VAT
After months of testing various products, we finally found an O-Ring size that provided perfect feedback whilst doing an effective job at damping switch noise.
Mechanical keyboards are amazing and with the gaming market becoming more geared up for using mechanical boards, OcUK has taken note of the increasing demand to reduce the only downside of Mechanical Keyboard use. Noise.
These O-Rings are designed to be rolled onto the stalks of the underside of Cherry MX mechanical keyboards. Each O-Ring serves as a damper for the key by reducing the 'throw' of each switch as well as softening the 'bottoming out' noise when a mechanical switch comes to the end of its 'throw'.
Whilst not removing all noise entirely, many of our testers have stated that it reduces noise and clatter from the keyboard as well as giving a softer and more pleasant typing experience.
Compatible with any Cherry MX Switch based mechanical keyboard.
Key Compatibility: Cherry MX
Color: Black
Material: Rubber
Outer Diameter: 8,0 mm
Inner Diameter: 4,8 mm
Thickness: 1,6 mm
Quantity: 125 pieces
Shore 40A
Material: EPDM
Only £6.95 inc VAT.
ORDER NOW
_____
Ducky ABS Pink Keycap Set with Laser Etched Printed - Shine @ £24.95 inc VAT
Replacement keycap set for Cherry MX Switch keyboards. Manufactured from ABS plastic with laser etched characters.
Fits all standard Cherry MX Switches.
ABS Plastic.
109 Key Set.
Top Printed Characters.
UK Layout.
Only £24.95 inc VAT.
ORDER NOW
