Today Only special offers! Save up to £20!!
Cooler Master HAF 912 Case - Black @ £46.98 inc VAT
Cooler Master adds another new member to the HAF series, the HAF 912. To carry the mission of providing the best thermal solutions, HAF 912 supports two 120 mm for external radiator and high-end CPU coolers. Furthermore, the spacious interior accommodates six 120mm fans for better and superior airflow yet, enough to fit 12 devices and high-end GPUs such as Radeon HD5970 and Nvidia GTX 480.HAF 912 features rugged looks, massive air cooling and trademark interior that signifies performance and makes it a killer machine.
- HAF 912 is built in aggressive design.
- The compact interior able to accommodates 12 devices.
- Supports long graphics cards including Radeon HD 5970 and NVIDIA Geforce GTX 480.
- Superior cooling performance support up to six 120 mm fans.
- Front 200mm fan with brilliant Red LED provides the best airflow to HDDs.
- Removable 3.5”HDD cage provides enthusiasts more convenient installation.
- Customized neat cable management.
- Dimension (W / H / D): 230 x 480 x 496 mm
- 5.25" Drive Bay: 4 Exposed (one could be converted to 3.5” bay)
- 3.5" Drive Bay: 1 Exposed ( converted from 5.25” bay) 6 Hidden
- 2.5" Drive Bay: 4 Hidden (two converted from 3.5” bay)
- I/O Panel: USB 2.0 x 2, Audio x 1, Mic x 1
- Cooling: Fan Bays Front: 120 mm red fan x 2, 1200RPM,17dBA (one is optional, can be swapped for one 200mm fan)
- Top: 120mm black fan x 2 or 200mm fan x 1 (optional)
- Rear: 120 mm black fan x 1, 1200 RPM, 17 dBA
- Side:120/140 mm fan x 1 (optional)
- Expansion Slots: 7 + 1
Only £46.98 inc VAT.
ORDER NOW
Turtle Beach Earforce Z6A 5.1 Analog Surround Sound PC Headset @ £65.99 inc VAT
The Turtle Beach Z6A PC headset combines the audio quality and comfort of a professional-grade gaming headset with the full impact and 3D positional accuracy of multi-speaker 5.1 surround sound. With eight premium speakers, including dual subwoofers, the Z6A is powered by a 5.1 channel amplifier with bass enhancement, letting you pinpoint critical sound cues from every direction.
Designed to deliver high quality 5.1 surround sound, the Z6A incorporates 4 premium speakers in each ear cup, including 40mm subwoofers for extended bass and extraordinary dynamic range. Providing more realistic directional audio perception, the front and surround speakers in the Z6A are acoustically angled, allowing you to more accurately pinpoint sounds than conventional flat speakers.
The Z6A amplifier gives you quick access to independent controls for all 5.1 audio channels, letting you tune your Z6A for any gaming situation. The headset and amplifier also feature a quick disconnect so you can easily detach it without having to unplug the 5.1 outputs from your computer.
Please Note: The Earforce Z6A requires that your PC has a 5.1 SS sound card to function as a surround sound headset. With a standard sound card the Z6A will only function as a stereo headset. See the Extra Info tab for more details.
• Multi-Speaker Surround Sound - Eight amplified speakers, including dual subwoofers bring true 5.1 surround sound to your gaming experience.
• Acoustically Angled Speakers - Specially angled speakers by Turtle Beach engineers delivers more realistic directional audio perception.
• 5.1 Channel Amplifier - Independent controls for all 5.1 audio channels on the Z6A amplifier allows for fine tuning on the fly.
• Quick Disconnect Cable - Easily detach your headset from your computer without unplugging all wires.
• Microphone Monitor - Hear your voice in the headset, so you won’t have to shout to hear what you’re saying.
• USB Powered - A USB connection provides power to your amplified PC gaming headset - no AC adapters or batteries necessary.
• XBOX 360 Compatible - Works as amplified stereo headset on the XBOX 360. Cable Required
Only £65.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
