Dive into the world of watercooling with the XSPC RayStorm 750 RS240 WaterCooling Kit V4, get better overclocks and have a quieter PC! You can also grab a Adata Premier Pro SP900 64GB 2.5" SSD for just £50!
XSPC RayStorm 750 RS240 WaterCooling Kit V4 @ £119.99 inc VAT
Kit Contents:
- RayStorm CPU Waterblock
- X2O 750 Bayres/Pump (Black) V4
- RS240 Dual Radiator
- G1/4" to 1/2" Barb (Black Chrome) x6
- Plastic Hose Clip x6
- XSPC 1650rpm 120mm Fan x2
- 120mm Fan Grill (Black) x2
- Intel and AMD RayStorm Brackets
- Socket 1366 and 1155/1154 Backplates
- Socket AM2 and AM3 mounting kit
- 80mm to 120mm Radiator brackets
- 3mm Twin Blue LED with 4Pin Molex
- 5mm Blue LED with 4Pin Molex
- 2 Meters of Clear 7/16? Hose
- 24pin ATX Bridge Tool
- K2 Thermal Paste
Supports:
AMD Sockets AM2, AM2+, AM3, AM3+
Intel Sockets LGA1366, LGA1156, LGA1155, LGA1150, LGA 2011
*Requires mounting holes
Designed for multi-core CPUs
Only £119.99 inc VAT.
ORDER NOW
Adata Premier Pro SP900 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (ASP900S3-64GM-C) @ £49.99 inc VAT
The Premier Pro SP900 SSD not only boasts impressive performance numbers, but also offers a competitive price advantage to those looking to upgrade. It is expanded capacity solid state drive which uses new optimized firmware to utilize greater storage capacity of the NAND Flash components drive. With superior NAND Flash, the Premier Pro SP900 reaches new levels of stability and performance, with a 7% increase in storage capacity over common SSDs in the market that use a SandForce controller.
The Premier Pro SP900’s maximum sequential read and write speeds are 555/530 MB per second, with maximum random 4k write speeds of 85,000 IOPS. Capacities of 64, 128 and 256 GB make this drive an outstanding option for upgrading notebooks that are compatible with the SATA 6Gb per second specification.
The Premier Pro SP900 SSD adopts specially selected Flash chips from reliable manufacturers, and supports the Windows TRIM command. The Windows TRIM optimization command can directly delete stored data in the Flash memory and release unused space (Free Blocks) to be used for system writes immediately. This results in more accelerated transfer and write performance for solid state drives, and is also effective in slowing down efficiency decline and depletion chances, maintaining effective operation and extending the life of the disk.
In both desktop and notebook computers, users will enjoy an unprecedented high-speed experience when they edit video, retouch large picture, and use computer drafting, reading and writing operations.
Features:-
- NAND Flash: MLC (Mulit-level cell) Asynchronous Flash
- Interface: SATA 6Gb/s
- Form Factor: 2.5 inch
- Dimensions: 100 x 69.85 x 9.5mm (L x W x T)
- Weight: 76g
- Feature: TRIM COMMAND SUPPORT, RAID SUPPORT, MAX 4K WRITE IOPS
- 128GB Performance (ATTO) :
- Read : Up to 550MB/s
- Write : Up to 505MB/s
- Multimedia Data Transfer (AS-SSD)
- Read : Up to 180MB/S
- Write : Up to 75MB/S
- MAX 4K write IOPS up to 85K
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Shock Resistance: 1500G
- Power Consumption: 0.9W Active; 0.5W Idle
- MTBF: 1,000,000 hrs
- Warranty: 3 year
- Accessories: 2.5" to 3.5" Bracket
- Acronis True image HD,disk Mirgration Utility
Only £49.99 inc VAT.
ORDER NOW
Kit Contents:
- K2 Thermal Paste
Supports:
ORDER NOW
Features:-
- Weight: 76g
- Warranty: 3 year
ORDER NOW
