Today's deals folks! Don't forget to check out our This Week Only too.
Lian Li PC-7FNWX Aluminium Mid Tower Case - Black @ £114.95 inc VAT
The PC-7FNWX carries Lian Li’s high standard of Quality requirement. All the sharp edges have been removed for user’s safety. In addition, the external and internal surfaces have hair-line brush anodized aluminum in keeping with Lian Li’s classical style. The PC-7FNWX is in a minimalism design; attractive anodized aluminum give a flamboyant finishing touch to this outstanding high-end chassis. With this classical design, it can fit in your living environment easily. The PC-7FNWX is a Mid-tower case, which is ideal for the latest graphics cards in combination with the best thermal dynamics. The component installation can be completed entirely without tools, and is easily adjustable to optimize your hardware setup. Especially in the advent of adding in new graphics cards, equipped with 8 PCI slots, this chassis can hold three or more graphics cards, supports CrossfireX™ and 3-way SLI™. There is a 140mm intake blue LED fan on PC-7FNWX, The fan can output high air flow volume with lower RPM to push the cold air through the HDD rack. The rear 120mm exhaust fan just next to the CPU, it can remove the hot air out fast and silently. There is a special quadrate opening of motherboard tray, users can easily switch the cpu's cooler without removing the motherboard.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports, e-SATA, Audio supports HD Audio. The dual design is for better compatibility options. All I/O ports on the top cover, allow for easy access, there is also a dust-free cover to protect these connectors.
- Dimensions: (W) 210mm x (H) 470mm x (D) 490mm
- Front bezel Material: Aluminum
- Side Panel: Transparent Side Panel
- Body Material: Aluminum
- 5.25" drive bay (External): 5
- 3.5" drive bay (Internal): 5
- Motherboard: ATX / M-ATX
- System Fan (Front): 140mm Blue LED Fan x 1
- System Fan (Top): None
- System Fan (Rear): 120mm Fan x 1
- I/O Ports: USB3.0 x 2 / e-SATA x 1 / HD Audio
Only £114.95 inc VAT.
ORDER NOW
OcUK Premium One Piece 8GB USB2.0 Stainless Steel Pen Drive @ £4.49 inc VAT
Premium Stainless Steel single piece crafted 8GB Overclockers UK branded flash pen finished in a sophisticated champagne. Featuring speeds of up to 15Mb/s Read and 12Mb/s write along with a 5 year Warranty. Featuring Kingstons Flash technology the Overclockers UK flash drive delivers admirably in all aspects of performance, value and design.
- Hi Speed USB 2.0 Compatible (backwards compatible to USB 1.1)
- Easy plug and play functionality
- Compatible with Windows® 7, Windows Vista®, Windows XP®, Windows 2000®, Windows® ME, Linux 2.4 and later, Mac® OS9, X and later
- Portable and light weight (5.5 grams)
- Up to 15Mb/s Read, 12Mb/s Write.
- Lanyard or Keyring attachable
- Dimensions: (LxWxD) 56x17x6mm
- 5 Year Warranty
- Capacity: 8GB
Only £4.49 inc VAT.
ORDER NOW
ORDER NOW
- 5 Year Warranty
- Capacity: 8GB
Only £4.49 inc VAT.
ORDER NOW
