Today we have two great monitors, perfect for gamers looking for a new monitor at a dash of the price. The BenQ G222HDL 21.5" Monitor for £99.98 brings LED backlight quality to you - if you haven't already seen LED back lighting it really is something new generation and special!
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £99.98 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 2 Years On-Site
Only £99.98 inc VAT.
ORDER NOW
LG E1951S 18.5" Widescreen LED Monitor - Glossy Black @ £66.98 inc VAT
Clear contrast of light and colour Enables display of Subtle differences. Even now CAN BE observed Blacks, is Considered the most Difficult to visualize the before. Intelligent LED technology saves energy and LG monitors Provides clear and vivid images
Specification:-
- Screen Dimensions: 18.5in
- Screen Type: LED TN 16.7 Million Colours
- Aspect Ratio: 16:9
- HD Support: Yes
- Resolution (Native): 1366 x 768 Pixels
- Brightness: 250cd/m2
- View Angle: 170° (Horizontal - Max) x 160° (Vertical - Max)
- Contrast Ratio: 5,000,000:1 (Dynamic)
- Response time: 5ms
- Anti-Glare / Anti-Static: Anti-glare, 3H
- VGA In: 1 x 15-pin D-sub
- Plug and Play: Yes
- Voltage/Frequency: 100 to 240VAC
- Power Consumption: 17W (Max) / 0.5W (Standby)
- Case Colour: Black
- Dimensions: 44.94cm (W) x 3.35cm (D) x 27.90cm (H) - Weight 1.60kg
- 3yr Warranty
Only £66.98 inc VAT.
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 3.8kg
ORDER NOW
Specification:-
- HD Support: Yes
- 3yr Warranty
ORDER NOW
