**TODAY ONLY! 11/02/2014** Thermaltake Urban S71 & Western Digital Caviar Red 3TB
OcUK Staff
4 Feb 2013
Thermaltake Urban S71 Windowed Midi Tower Case - Black @ £112.99 inc VAT
Urban S71 windowed mainstream full-tower, categorized in Thermaltake latest chassis collection – Urban Series. The entire series has a simple and elegant aesthetic, design for users who looks for everything but a flamboyantly appearance.
Features:-
- Exquisite Design
Built with brushed aluminum finish front door panel to mask the extrusive drive devices, not only unify the appearance, but also provide a simple yet sophisticate aesthetic.
- Handy I/O ports
The front-top panel has implemented two of latest data transfer SuperSpeed USB 3.0 ports along with two USB 2.0 ports, a HD microphone and headset jacks, to grand direct access when needed.
- Easy Hot Swap
Top-mounted 2.5” or 3.5”HDD Docking Station enables blazing fast file transfer and effortless hot-swap drive replacement design for easy setup or removal of HDD.
- Innovative tool-less design
The latest tool-less innovation with 5.25” & 3.5” tool-free drive bay design minimized the hassles of installing ODD and HDD devices.
Specification:-
- Case Type: Full Tower
- Side Panel: Transparent Window
- Colour: Exterior & Interior : Black
- Material: SECC
- Expansion Slots: 8
- Motherboards 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX), 12” x 13” (Extend ATX)
- I/O Ports: USB 3.0 x 2, USB 2.0 x 2, HD Audio x 1
- PSU Standard PS2 PSU (Optional)
- LCS Upgradable: Supports 1/2” ,3/8”,1/4", water tube
- Fans:-
- Top: 1 x 120mm or 2 x 120mm
- Rear: 1 x 120mm
- Cooling System:-
- Front (intake) : 200 x 200 x 30 mm fan (600~800rpm,13~15dBA)
- Rear (exhaust) : 120 x 120 x 25 mm Turbo fan (1000rpm,16dBA)
- Top (exhaust) : 200 x 200 x 30 mm fan (600~800rpm, 13~15dBA)
- Bottom (intake) : (Optional) 120 x 120 x 25 mm fan or 140 x 140 x 25 mm fan
- Drive Bays:-
- Accessible : 3 x 5.25’’, 1 x 3.5’’
- Hidden : 5 x 3.5’’ or 2.5’’
- Docking : 1 x 3.5” or 1 x 2.5”
- Dimension: 534(H) x 213(W) x 584(D) mm
- Net Weight: 10.5Kg / 23.2 lb
*CPU cooler height limitation: 160mm VGA length limitation: 344mm
Only £112.99 inc VAT.
ORDER NOW
_____
Western Digital Caviar Red 3TB SATA 6Gb/s 64MB Cache WD30EFRX - OEM HDD @ £89.99 inc VAT
WD Red is the only hard drive designed for NAS systems that have 1-5 drive bays. The drives are designed and extensively tested for compatibility in the unique 24x7 operating environment and demanding system requirements of home and small office NAS.
- Capacity: 3TB
- Cache: 64MB
- Interface: SATA 6GB/s
- Spin Speed: 5900RPM
- Warranty: 3 Years
Only £89.99 inc VAT.
ORDER NOW
I did check it out. The price on the 3Tb was amazing the one on the 4Tb seems the going rate sadly and I would rather buy from ocuk when the price is right! I need a few so a few quid will help.
