Silverstone SST-PS08W Precision Midi-Tower - White @ £19.99 inc VAT
The new Precision series PS08 was created with the goal of exceeding user experience and expectation for affordable PC chassis by offering a wide range of features and complete it off with great build quality. A full array of features like USB 3.0, removable fan filter, all black painted interior and CPU back plate cutout are all standard in this great chassis. The top mounted power supply allows for easier installation and the cleverly designed interior allows up to four 3.5” HDD, one 2.5” HDD and up to 14.1” long graphic card to be installed. For those requiring a quality enclosure with great styling and flexibility, the PS08 is an excellent choice.
Features:-
- Quick access filters to prevent dust buildup
- Motherboard back plate opening for quick CPU cooler assembly
- Support four expansion slots cards up to 14.1 inches long
- All black painting inside with stylish look
- Highly flexible drive storage options
Specification:-
- Material: steel, plasticso lik
- Colour: White
- Form Factor: Micro-ATX, Mini-ITX
Fan:
- 1x 120mm (front)
- 1x 80 mm (front optional)
- 1x 92/80 mm (rear optional)
- Filters: Front
Drive Bays:
- 2 x 5.25 inches (external)
- 4 x 3.5 inch (internal)
- 1x 2.5 inch (internal)
- Expansion Slots: 4
- Power supply (optional): Standard ATX (max. 210 mm length)
I / O Panel:
- 2x USB 3.0 (internal connector)
- 1x each Audio In / Out
- Maximum video card length: 358 mm
- Maximum CPU cooler height: 140 mm
- Dimensions: 168 x 355 x 400 mm (W x H x D)
- Weight: 3.46 kg
Only £19.99 inc VAT.
ORDER NOW
______
TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD316G1600HC11DC01) @ £79.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- CL-tRCD-tRP-tRAS 11-11-11-28
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Heat Sink Aluminum heat-sink
- Working voltage 1.5V± 0.075V
- Warranty Lifetime warranty
Only £79.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- Colour: White
Fan:
- 1x 120mm (front)
- Filters: Front
Drive Bays:
I / O Panel:
- Weight: 3.46 kg
ORDER NOW
______
Features:-
ORDER NOW
