Morning people! Don't know about you lot, but the sun here has gone - and it's in with the rain
BUT DO NOT BE SAD! Overclockers UK are here to brighten the day a bit with a giant ray gun... I mean, some great offers!
Gainward GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card - ONLY £539.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 902 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ONLY £539.99 inc. VAT
CLICK HERE TO GET YOURS NOW!
_
Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9B) - ONLY £71.99 inc VAT
Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking. They’re available in multiple colors to let you match your Vengeance Pro memory to your system’s color scheme.
As a bonus, they’re priced to deliver class-leading value, so you’ll have more room left in your system build budget.
Features:-
- Each Vengeance Pro Series module is built from an eight-layer PCB and highly-screened memory ICs. The efficient heat spreader provides effective cooling to improve overclocking potential.
- The heat spreader doesn’t just allow Vengeance Pro Series to run better–the aggressive yet refined form factor looks great in showcase systems. The color accent clip lets you match your Vengeance Pro
Series memory to your system’s color scheme.
- Vengeance Pro Series memory is optimized for performance on the latest 3rd and 4th generation Intel® Core™ platforms. XMP 1.3 profile support makes stable overclocking easy and automatic.
- The Vengeance Pro Series module height is carefully designed to fit easily in most system while still providing ample cooling performance and that edgy look
Specification:-
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz
- XMP 9-10-9-27 values at 1866MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1866MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Haswell & Richland compatible
ONLY £71.99 inc VAT
So, don't miss out... GOGOGOGOGOGO!
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
_
Features:-
Specification:-
- Lifetime Warranty
ONLY £71.99 inc VAT
