Get a load of today's deals before they are snapped up by others! Absolutely stonking deal on the MSI graphics card with a free Corsair Vengeance mouse, 8 popular games + OcUK Mouse Pad
Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM @ £7.99 inc VAT
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
PWM is a widely available feature on all current Intel and AMD platform based motherboards. It is more accurate than voltage regulation, energy saving and a fully automatic way of controlling the fan speed. PWM provides ultra quiet acoustics during normal PC use and high performance cooling under high system load. The Optional Akasa AK-CB002 cable adapter can provide the system with two additional PWM connectors if needed.
- Super silent APACHE fans in camouflage colours
- S-FLOW fan blade design delivers 30% higher airflow
- IP-54 military standard moisture and dust protection
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 26.40 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Only £7.99 inc VAT.
ORDER NOW
MSI HD 7970 Lightning BOOSTED Edition 3072MB GDDR5 PCI-Express Graphics Card with FREE Corsair Vengeance M65 Mouse & OcUK Mega Mat!! @ £379.99 inc VAT
Unlocked Digital Power
- Unlocked BIOS: One click to unlock all protections for extreme overclocking
- Digital PWM Controller: More stable and precise voltage by digital signal
- Enhanced Power Design: 2X Power output for maximum OC potential
GPU Reactor
- An add-on device on the back of R7970 Lightning (Behind GPU) for the overclocking stability
- Provide 88% higher power capacity and eliminate power noise (ripple)
Xtreme Thermal
- Dust Removal technology on Twin Frozr IV keeps dust out for the best thermal condition
- Dual Form-in-one Heatsinks provide better heat dissipation and strengthen the structure
Military Class III Components
- Meet MIL-STD-810G standard to ensure the best stability and quality.
- Adopt CopperMOS, Hi-c CAP, Golden SSC, and Dark Solid CAP
Graphics Engine ATI Radeon HD 7970
Interface PCI Express x16 3.0
Memory Type GDDR5
Memory Size(MB) 3072
Memory Interface 384 bits
Core Clock Speed(MHz) 1070
Boost Clock Speed(MHz) 1150
Memory Clock Speed(MHz) 6000
DVI Output 2
Mini DisplayPort 4
HDCP Support Y
HDMI Support Y
Display Output (Max Resolution) 2560x1600
RAMDACs 400
DirectX Version Support 11
OpenGL Version Support 4.2
CrossFire Support Y
Card Dimension(mm) 305x135.5x40mm
with FREE Corsair Vengeance M65 Gaming mouse & OcUK Mega Pad, plus 8 FREE games!!
Warranty 3 Year
Only £379.99 inc VAT.
ORDER NOW
- Rated voltage 12V
Only £7.99 inc VAT.
ORDER NOW
GPU Reactor
Xtreme Thermal
Memory Type GDDR5
DVI Output 2
Mini DisplayPort 4
HDCP Support Y
HDMI Support Y
RAMDACs 400
CrossFire Support Y
Warranty 3 Year
ORDER NOW
