Today you can convert your 2.5" SSD or Hard drive into a portable hard drive. By essentially creating your own external hard drive you are saving a good bit of money than buying a brand new external.
We also have the Pioneer BDR-206DBK 12x BluRay RW for users who want to experience 1080p BLU RAY movies which they own on Disc or if they need a large format CD to back their data up onto this drive also offers a re-writable solution
Lepa Screwless USB2.0 2.5" Hard Drive Enclosure @ £1.49 inc VAT
An interestingly designed USB2.0 2.5" HDD and SSD enclosure, ideal for making your storage medium truely portal.
- USB2.0 Interface
- Max data transfer rate: 480Mb/sec
- USB Powered
- Supports HDD's up to 10,000RPM
- Gorgeous upper cases: match your style
- Zero-screw designfor easy assembly
- Air vents design for maximum heat dissipation
- "Plug & Play" supported
- Supports 2.5” SATA I & II HDD and SSD (9.5 mm high)
- Dimensions: 127mm x 74mm x 16mm
Only £1.49 inc VAT.
ORDER NOW
Pioneer BDR-206DBK 12x BluRay RW / 16x DVD±RW Drive - Black (OEM) @ £67.98 inc VAT
Pioneer’s BDR-206DBK is the first BDXL drive, which supports triple-layer BD-R (write-once) and BD-RE (rewritable) discs with huge capacities of 100GB, and even 128GB quad-layer
Key Features:-
- Max Write Speed: 16x DVD, 12x BD-R, 40x CD-R
- Max Read Speed: 16x DVD, 8x BD, 40x CD-R
- 4MB buffer memory
- Serial ATA (SATA) interface
Only £67.98 inc VAT.
ORDER NOW
- USB2.0 Interface
- USB Powered
Only £1.49 inc VAT.
ORDER NOW
Key Features:-
- 4MB buffer memory
ORDER NOW
