**Today Only 12/03/2012** Corsair Flash Voyager 8GB USB3.0 & Prolimatech Samuel 17 CPU Cooler
22 Aug 2010
Today only deals for Monday guys!
Corsair Flash Voyager 8GB USB3.0 Flash Drive
(CMFVY3S-8GB) @ £11.99 inc VAT
Get faster read speeds and rugged reliability with the Corsair Flash Voyager USB 3.0 flash drive. USB 3.0 read speeds let you access movies, pictures and large files up to 4x faster than traditional USB 2.0 drives and the durable rubber design is water resistant and shockproof to keep your data safe.
Fast – Access videos, pictures and large files up to 4x faster read speeds than traditional USB 2.0 drives
Durable – Corsair's proprietary all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data.
Shock Proof – Solid state storage makes Flash Voyager drives virtual shock proof.
Convenient – Just plug it in and go! Works with Windows, Mac OS X and even Linux without drivers.
Compatible – Designed for USB 3.0, backward compatible with USB 2.0
Backed by Corsair – A respected name with a passion for quality and customer service.
- Fast USB 3.0 connectivity;
- Durable rubber housing;
- Water resistant;
- Shock proof;
- 5 Year Manufacturer Warranty;
Only £11.99 inc VAT.
ORDER NOW
Prolimatech Samuel 17 CPU Cooler @ £33.98 inc VAT
In the Old Testament of 1 Samuel, Chapter 17 tells a story of an ordinary man named David whom nobody believed in. That did not matter to him because David had something to put his trust and faith in. From that he would get his strength to battle the nine-foot-tall giant, Goliath. In the end, against all odds, David did prove that size does not matter when he defeated Goliath.
Prolimatech Samuel 17 has the essence of David. It is compact in size but don’t let that fool you as it packs a deadly arsenal in a never ending battle against heat. When equipped with a 120mm, Samuel 17 will not only cool your CPU efficiently but also the PC components around it, keeping your computer running smooth and stable.
- Unique 6-high quality-heatpipe-down-draft style CPU heatsink.
- Super compact heatpiped CPU cooler at 45mm tall, perfect for HTPC system.
- No installation interference issue.
- Supports low RPM 120mm fans on a relatively smaller heatsink body.
- Decreases temperature on surrounding PC components.
- Supports ATX, microATX and mini-ITX form factors.
- Supports Intel LGA775/1156/1366 and AMD AM2/AM2+/AM3/AM3+.
- Suggested Fan: 120mm X 25mm or 120mm X 12mm
- Suggest Fan Speed: 1000~2000rpm
- Suggest Noise Level (dBA): Below 26dBA
- CPU Platform: Intel Socket LGA 775/1366/1156/1155 and AMD AM2/AM2+/AM3/AM3+.
- Heatsink Dimension: (L)121.2mm X (W)120mmX (H)45mm
- Heatsink Weight: 410 g
- Heatpipe: Ø 6mm X 6pcs
Only £33.98 inc VAT.
ORDER NOW
Why are original prices never shown? I have not been tempted by any of the offers here for a while now just because I cannot quickly tell whether I am saving £10 or 50p by going and looking at other websites.
