Morning people of the internets. Have a gander at our "Today Only Deals"!
HIS HD 7790 TURBO 1024MB GDDR5 PCI-Express Graphics Card @ £99.95 inc VAT
Turbo cards are faster than regular cards! The card is bios-overclocked out of the box with 1075MHz / 6400MHz core clock and memory clock.
The card is equipped with the widely acclaimed HIS iCooler – certified by HIS that the card is quiet with noise level below 28dB when watching movies, surfing Facebook, working. . HIS iCooler provides an outstanding cooling performance and quiet environment. With HIS iCooler, the life span of the card is maximized while the noise level is minimized! You feel the quietness when viewing photos, browsing webs and checking your email.
Features:-
- Core Clock: 1075MHz
- Memory: 1024MB GDDR5
- Memory Clock: 6400MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 896
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x DVI, 1x HDMI & 1x DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Only £99.95 inc VAT.
ORDER NOW
_
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP4G3D1608DE1TX0CEU) @ £49.99 inc VAT
'Designed specifically for computer gamers and power users seeking maximum seeking maximum system performance and stability, the Crucial Ballistix high performance memory line features advanced speed grades, low latencies, and integrated aluminium heat spreaders. With Ballistix memory, you can push the performance envelope.
- Black PCB
- Black high performance ALU heatspreaders
- Ultimate performance memory
- Temperature Probes
- Crucial MOD software compatible
- Each two module set is tested at 1600MHz
- Elite heat spreader for performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge/Ivybridge compatible
- Bulldozer compatible
Only £49.99 inc VAT.
ORDER NOW
Features:-
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
_
- Black PCB
- Lifetime Warranty
ORDER NOW
