**TODAY ONLY! 12/06/2015** Aerocool Strike-X 1100W '80 Plus Gold' Modular PSU & Ignition eSport LAN
OcUK Staff
4 Feb 2013
Aerocool Strike-X 1100W '80 Plus Gold' Modular Power Supply @ £104.99 inc VAT
Introducing the new Strike-X series from AeroCool - the ultimate gaming equipment for gamers and enthusiasts world-wide! The Strike-X series includes a wide range of gaming equipment from cases to PSUs to fan controllers to speakers, in fact everything the gamer would require will soon be available.
Like all Strike-X products, the Strike-X power supplies bear the distinct "X" mark on the top aluminium frame cover. The "X" also appears on a sticker at the side of the PSU. The Strike-X power supplies are designed with the concept of "POWER", "STYLE" and "COOL" and they are perfect for those power-hungry gaming systems and look cool to show off!
All of the Strike-X Power supplies feature a very quiet 139mm fan with noise levels starting from just 16 dBA. The noise level will increase depending how much wattage the PSU uses to power the system (take a look at the graphs at the bottom of this page for more information).
The PSUs are physically the same size with the major difference being the wattage they provide. Also the 800 and 1100W version are modular unlike the 500 and 600W PSUs. The only other difference worth mentioning is that while the PSUs are 80+ certified, the 1100W model is 80+ Gold which means, at its peak, it is over 90% efficient!
- Compatible with ATX 12V 2.3 and EPS 12V 2.92
- Low Noise 13.9cm Fan with intelligent fan speed control
- High-Efficiency 80+ Certified
- Active Power Factor Correction (PF>0.99)
- Green power design that meets EuP requirements
- Safety / EMI Approvals: CE, CB, TUV, FCC, UL
- Dual GPU Support
Only £104.99 inc VAT.
ORDER NOW
_______
"Ignition eSport LAN Gaming PC" Intel Core i5 4690, GTX 960 2GB Gaming PC - Black/Red @ £574.99 inc VAT
Introducing the Ignition series of pre-built, pre-tested, off the shelf PCs. The "Ignition eSport LAN" is a Gaming Cube PC based on the Intel Haswell architecture. Equipped with Intel's latest quad core processor and Nvidia GeForce GTX 960 Graphics this is an powerful, great value gaming PC!
OcUK's Express systems are built to the same standard and using the same high quality components as our premium gaming PCs. They are pre-configured and waiting on the shelf ready for in store collection or next day delivery.
Key Features of this PC
- Quad Core processing & 8GB of DDR3 memory
- Powerful Nvidia GeForce Graphics Technology
- Off the shelf convenience
System Specification
- Case: BitFenix Neos ATX Tower Black/Red
- Power Supply: SuperFlower HX 450W "80 Plus Gold" Power Supply
- CPU: Intel Core i5 4690 Quad Core Processor
- Motherboard: Asus Z97-K Motherboard
- Cooler: Raijintek Aidos Direct Contact CPU Cooler - Black
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 1TB 7200RPM Seagate Barracuda HDD
- Graphics Card: GeForce GTX 960 2048MB GDDR5 Graphics Card
- Sound: Realtek 7.1 Channel HD Sound (On-Board)
Service Package
- Full 36 Month warranty - 24 Month Collect and Return with a further 12 months labour (Mainland UK and Ireland Only - Return to Base warranty for customers outside of the UK) - Each specification is assembled from handpicked components for compatibility and stability - Telephone, web note and forum technical support
Note - These systems are preconfigured, pre-built and do not include an operating system. This means that you will need to install your own operating system of choice and the specifications are not flexible.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
Free games provided in conjunction with any components are only provided with this PC if specifically stated in the description above.
Only £574.99 inc VAT.
ORDER NOW
Are the aerocools so cheap because their quality is average or because they are trying to gain a foothold in the market?
They are rubbish. There are only 2 reviews for the strike-X range and both are for the 800w version. One gives it a 6/10 and the other says't it's not a failure but it also not good. With the massive choice in psu's these days I see little point in going for a psu that get's less than 9/10.
