Hazro HZ30WiE V2.0 10-Bit 30" LED Widescreen Professional Monitor - Black **CLEARANCE** @ £359.99 inc VAT
**CLEARANCE SALE, BRAND NEW WITH 1yr WARRANTY**
The Hazro HZ30WiE V2 is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30WiE V2 performs with consistency and clarity to optimise your visual experience. The Hazro HZ30WiE V2 recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30WiE V2 collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30WiE V2, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30WiE V2 offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30WiE V2 is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- Aluminum Casing
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Connectivity: 1x DisplayPort, 1x DVI, 1x HDMI & 1x VGA
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 1yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Only £359.99 inc VAT.
ORDER NOW
______
Iiyama Prolite GB2773HS-GB1 144Hz 27" Widescreen LED 1MS Monitor - Black @ £209.99 inc VAT
The 27’’ ProLite G2773HS is a real game changer. The use of a high quality 144Hz panel with a blistering 1ms Response Time offers you an amazing gaming experience. The screen offers crystal clear, smooth and judder free graphics during fast paced games and beautiful quality HD video. Hardcore gamers will really appreciate the few milliseconds advantage this screen gives you, allowing split second game changing decisions. The screen comes equipped with stereo speakers and a headphone socket as well as HDMI, VGA and Dual Link DVI connections and boasts a 1920 x 1080 Resolution. The LED Back Light system offers great clarity and brightness.
iiyama has supported the Pro Gamer industry for over 5 years now and support gaming teams such as Team Dignitas (UK) and Low Land Lions (Holland), and are the monitor of choice for any discerning Gamer. iiyama continues to focus and support the vitally important competitive gaming industry , which is rapidly becoming one of the largest industries in the world, and gaming in general now out performs Hollywood in world wide revenue.
Features:-
- Height adjustable stand
- Diagonal: 27"
- Panel: TN, LED-backlit
- Display area h x w: 336.3 x 597.9 mm; 13.2" x 23.5"
- Response time: 1 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch h x v: 0.3113 x 0.3113 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync DVI: 30 - 140 KHz
- Vertical sync DVI: 55 - 120 Hz
- Synchronization: Separate Sync
- Aspect ratio: 16 : 9
- Analog input connector: D-Sub
- Digital input connector: DVI-D, HDMI
- HDCP: yes
- Dimensions w x h x d: 647 x 454.5 x 239 mm
- Weight: 5.6 kg
- Height adjustable stand: Yes
- Height adjustment: 130mm
- Rotation (pivot function): 90°
- Swivel Stand: 90°; 45° left; 45° right
- Tilt angle: 22° up; 5° down
- VESA mounting: 100 x 100 mm
- Warranty: 3 Year On-Site
Only £209.99 inc VAT.
ORDER NOW
Features:-
- Aluminum Casing
- DPMS / OFF: <2W
- 1yr Warranty
ORDER NOW
______
Features:-
- Diagonal: 27"
- HDCP: yes
- Weight: 5.6 kg
ORDER NOW
