**TODAY ONLY! 12/11/2013** Inno3D GeForce GTX 780 & AOC 29" Super-Wide Monitor!
OcUK Staff
4 Feb 2013
Two fantastic deals this morning for you. Chance to upgrade your GPU or go SLI - AND to get that monster of a monitor. Grab 'em before they go! :)
Inno3D GeForce GTX 780 iChill HerculeZ X3 Ultra DHS Edition 3072MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
This DHS Edition utilises a carefully hand selected and heavily binned GTX 780 GPU, making it ideal for overclocking. Along with the iChill HerculeZ X3 Ultra cooler these cards feature huge overclocking potential.
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780 (Specially selecting Binned GPU for maximum OC Potential)
- Core Base Clock: 1046 MHz
- Core Boost Clock: 1085 MHz
- Memory Clock: 6212 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £479.99 inc VAT.
ORDER NOW
__
AOC Q2963PM 29" Professional Super-Wide LED Multimedia Monitor - Gunmetal @ £299.99 inc VAT
AOC’s Q2963PM greatly enhances your productivity and experience; work and leisure won’t be the same with features like the ultrawide cinematic screen, screen-splitter function, and dual link-up. Whether it’s for viewing multiple documents, a more immersive movie and gaming experience, or multitasking simplicity, the 29” Ultrawide 21:9 screen monitor gives you what you need.
The AOC 29” UltraWide features an LED Backlit screen that offers brilliant color and ultra clear images. The full HD 1080P Resolution, with 50,000,000:1 contrast ratio and response time of 6ms, creates superior picture sharpness and the In Plane Switching (IPS) Panel allows you to view your spreadsheets or weekend movies from virtually any angle without compromising color uniformity.
The UltraWide is available for multiple full sized applications as an upgrade to dual monitor settings. Enjoy dual monitor productivity on a single screen. The vast panoramic screen is easy on the eyes, and with the screen-splitter function, multitasking has never been so simple.
The AOC 29” UltraWide screen and equipped dual 3 Watt enclosed speakers deliver a more awesome immersive experience for your favorite movies or games. The narrow bezel frame offers a sleek cinema-like screen experience.
The AOC 29” UltraWide’s connectivity is ultra-useful. The HDMI Connections carry high definition picture and sound in one easy cable. The HDMI with MHL allow you to connect your smartphone easily without a network connection. You can stream videos from your phone on to the monitor screen while charging your mobile device at the same time.
The PIP/PBP Hardware Calibration Ready (Dual Link Up) allow two devices to be viewed on the monitor simultaneously. The DisplayPort connection allows you to connect several monitors to your notebook with one simple cable.
The AOC 29” UltraWide is EnergyStar qualified, which means it uses about 30% less energy than standard units. Plus, it has no arsenic in the glass, mercury-free LED, and no BFR/PVC Laminates. It also qualifies for the latest standards such as TCO and Energy Star.
Features:-
- Panoramic screen with screen-splitter function for multitasking ease
- Cinematic Screen with 21:9 Aspect Ratio
- WFHD maximum resolution of 2560 x 1080 @60Hz
- PBP or PIP multitasking function for enjoying an image from two sources at once
- Multimedia connectors for VGA, DVI-D with HDCP, HDMI (MHL), DisplayPort
- Mobile High-Definition Link (MHL) to connect and charge the phone
- IPS Panel with full HD 1080P and an LED backlit screen
Specification:-
- Viewable Image Size: 29" (21:9)
- Brightness (typical): 300 cd/m2
- Contrast Ratio: 50000000:1
- Response Time: 5ms
- Optimum Resolution: 2560 x 1080 @ 60Hz
- Colors Supported: 16 Million
- Inputs: RGB D-Sub, DVI-D, HDMI & DisplayPort
- Built-in Stereo Speakers: Yes / 6W
- ENERGY STAR ? Compliant: Yes
- EPEAT Rated: Yes
- Dimensions (WxHxD): 713.57 x 387.91 x 211.99 mm
- Warranty: 3yr
Only £299.99 inc VAT.
ORDER NOW
Quite like the look of the monitor, wouldn't films and games look odd at that resolution?
I'm assuming 16:9 ratio films will have black bands down the sides. 21:9 ratio films will have bands around all sides until you expand it to fill. Unfortunately, this means that you're actually watching an upscaled image, so the quality won't be as good. This is down to the way that 21:9 films are encoded on discs. They are actually 800(ish) pixels tall rather than 1080 as the black bars are fixed onto the image. They really didn't think it through when they ratified the format :/
http://en.wikipedia.org/wiki/Philips_Cinema_21:9_TV
Don't understand why these are still £399+.
If I was going to buy a card now it would be an R9 290 and then just install a cooler, it would work out cheaper. :confused:
Try £350 nvidia, they are not worth £400 anymore.
So you'll spend £310 on a 290, ~70 on an aftermarket cooler and void your warranty?
Just buy a windforce/phantom 780 instead and get 3 great games.
The card on offer is the "DHS" model, remains to be seen if it's worth the premium or not but you can hardly compare it to a reference 290.
Big deal, most of the cards will clock to the stock speeds of this card and go way beyond them, only reason to buy this is for the extra overclocking headroom and even that isn't guarantied.
Anyway, you have a choice of Prolimatech MK-26 or Arctic Accelero Xtreme III for R9 290, Arctic Accelero Xtreme III costs around £45.
I'm not recommending the DHS version, don't know if the cherry picked chips are worth it but buying a 290 with the intention of fitting your own aftermarket cooler and voiding your warranty just seems a little silly when the 780s are there at 383 with 3 great games.
Sell games and enjoy a better card (subjective) with warranty imo.
I've returned a few cards with "void warranties", just slap on the stock cooler, in my cases they never checked. :p
Also the XFX cards allow the installation of 3rd party coolers, so in that case it does not void warranty.
£383 isnt so bad, still a little higher than they should be imo but £479.99 doesnt make any sense now.
As for the games, if your a gamer you probably already have them.
I'm a little bit annoyed, I ordered the Monitor yesterday while there were still a few left at £299.99, chose finance as I had used finance before without any issue, had to wait until today for an answer from them which was that I was declined this time for some reason. During the finance application it says if you are declined that the deposit can be put towards full payment of the item/s. So I rang up, said I ordered with finance but was declined, here's my order number can I just pay for it all now, I was told yea sure, no problem however the Monitor that I ordered while it was at £299.99 I could no longer have it at that price, I had to pay full price of £359.99! Well surely if I ordered it at £299.99 and the outstanding order said £299.99 I should still be able to have it at £299.99!?
