Today Only, grab yourself a top quality EVGA 460 for only £107.99! The card will smash through the latest games and perfect for SLI.
We also have the very custom Saitek Cyborg R.A.T. 7. Configure the mouse to the shape of your hand, add weights or change the shape of the palm rests. The choice is up to you!
EVGA GeForce GTX 460 Superclocked 1024MB GDDR5 PCI-Express Graphics Card @ £107.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 763MHz
- Memory: 1024MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1526MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years (If registered within 30 days of purchase)
Only £107.99 inc VAT.
ORDER NOW
Saitek Cyborg R.A.T. 7 5600 DPI Gaming Mouse @ £64.98 inc VAT
Play to win with the R.A.T. 7. Uncompromising, unparalleled, and unmatched, the R.A.T. 7 helps you play like the pros, combining state-of-the-art technology with a jaw-dropping array of customizable features to produce the next step in the evolution of the mouse. Perfect your grip – How do you hunt? Whether you ‘palm’ the mouse or ‘claw’ it, the R.A.T. can quickly and easily adapt by adjusting in length to suit your hand size and grip style. In addition, the Thumb Panel of the R.A.T. 7 moves forwards, backwards, and pivots outwards, giving you perfect positioning for effortless gaming.
- 3 Palm Rests: One featuring the same soft-touch finish as found on the body of the R.A.T., one with a rubber inlay for enhanced grip and one that is 4mm thicker to increase the height of the R.A.T.
- 3 Pinkie Grips: One featuring the same soft-touch finish as found on the body of the R.A.T., one with a rubber inlay for enhanced grip and one that offers a ‘wing shaped’ design, allowing you to rest your pinkie finger during play for increased grip.
- Custom Weight System – Like it light or heavy? Maybe you change the weight to suit your game? No matter, the R.A.T. has you covered. Five 6-gram weights can be added or subtracted in an instant, giving you the perfect weight for a perfect feel. When not in use, the weights can be safely stored in the supplied Weight Storage Container.
- Precision Aim Mode – Hit your target the first time every time. Use the ST Programming Software to set your desired Precision Aim speed (mouse sensitivity), then hold down the Precision Aim button to slow down mouse movement to a level that works for you. A deadly weapon that will hit your enemy where it hurts.
- 5600 DPI – Featuring a new generation ‘twin eye’ laser sensor that reads each axis separately for pinpoint accuracy, the R.A.T. 7 tracks up to a stunning 6 meters per second. Pro gamers who favor low sensitivity with high movement speed preferences will always experience correct tracking and precision.
- 4 Custom DPI Settings – Use the Rocker Switch to toggle between your custom DPI settings.
- 5 Programmable Buttons – Combine your Programmable Buttons with 2 regular left and right mouse buttons and give yourself a total of 7 buttons available to punish your competition. Assign your choice of key gaming actions to Programmable Buttons to create your own custom profiles.
- 3 Cyborg Modes – Toggle between three individual R.A.T. modes at the touch of a button. Change sensitivity or Programmable Button actions in an instant and gain immediate access to a mind-boggling 15 commands!
- Powerful ST Programming Software – Change your DPI, set Precision Aim cursor sensitivity, create custom profiles for each game, and assign commands to your Programmable Buttons and Modes. Easy, quick and the power you need right on your desktop.
- Lightweight Metal Chassis – Strong yet nimble, the solid metal frame forms the core of the R.A.T. 7 for enhanced rigidity.
- DPI range – 25-5600dpi (in 25dpi steps)
- Acceleration – 50G
- Polling Rate – Dynamic up to 1000Hz
- Tracking Speed – Up to 6m/sec
- Always On – Yes
- PTFE Slick Feet
- Gold plated connector – Yes
- Braided cable - Yes
Only £64.98 inc VAT.
ORDER NOW
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
ORDER NOW
- Always On – Yes
- PTFE Slick Feet
ORDER NOW
